Attribute Rules FC in AGS Desktop
2228
08-24-2022 06:40 AM
SachinChand
I'm new to AGS Pro and started playing with Attribute Rules (AR) in a File GDB.  After setting up some attribute rules on a feature class in the file gdb, I'm not able to load this feature class in AGS Desktop.  Desktop gives the error below. Wondering what the issue is.
3 Solutions
JohannesLindner
If by Desktop you mean ArcMap, then yes. This is expected behavior, Tables with Attribute Rules can not be opened in ArcMap.
Have a great day!
Johannes
JohannesLindner
See also the notes in this link: Introduction to attribute rules—ArcGIS Pro | Documentation
Have a great day!
Johannes
JohannesLindner
Yes, exactly. You can not work with the feature class in ArcMap.
What you can do is create a database view or query layer (in an Enterprise GDB). This view will be viewable (but not editable) in ArcMap.
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
SachinChand
Johannes, thank you for the reply.  Yes, I meant ArcMap/ArcCatalog.  I understand that the attribute rules cannot be opened in ArcMap.  Are you saying the feature class itself also cannot be opened in ArcMap?
JohannesLindner
Have a great day!
Johannes
SachinChand
Thank you!
JohannesLindner
Have a great day!
Johannes
