Arcade modify only Z geometry
1846
12-28-2023 06:34 AM
FlorentChalvet
Hello everyone,
In the exemple below, i can create another point with the Z coordinate of the field "Z_OUV" in stead of the original Z coordinate. But is it possible to modify the current point and not create another one?
if ($feature.Z_OUV == Geometry($feature).z) {
  return
var newGeom = Point({
  hasZ: true,
  x: Geometry($feature).x,
  y: Geometry($feature).y,
  z: $feature.Z_OUV,
  spatialReference: { wkid: 4326 }
var featureID = $feature.OBJECTID;
var f = filter(FeatureSetByName($datastore, "WaterDevice"), "OBJECTID = @featureID");
if (count(f) == 0) return $feature.Z_OUV;
var featureAct = first(f);
return {
  "result": $feature.Z_OUV,
  "edit": [{
    "className" : "WaterDevice",
    "updates" : [
      "OBJECTID": featureAct.OBJECTID,
      "geometry": newGeom
I tried to just update the "z" in the geometry section, but was met with an error. Is there a way to just modify one coordinate?
"geometry": {"z": $feature.Z_OUV}
Bud
Legendary Contributor
I remember trying something similar a while back, but I wanted to change the M-values of lines. I’m too rusty to help at this point, but you could check out my old M-value posts:
FlorentChalvet
Hey!
Thanks for the reply. I've checked your old posts, and there was the explanation for why it didn't work.
If geometries are immutable, then I don't think I can modify only one attribute of the geometry...
MikeMillerGIS
Esri Frequent Contributor
You need to pass back a complete geometry object.  So copy your geoemtry(can do this by calling Dictionary(geo) on it, prior to 3.2, you need to call Dictionary(Text(geo))).  Modify the Z and then pass that dict into the geometry constructor.
FlorentChalvet
Hey! I'm on 2.8 right now. Working with a Dictionary is doable, but I still create a new geometry who has the exact same attributes as the first one instead of modifying the current one.
var newGeom = Dictionary(Text(Geometry($feature)))
newGeom['z'] = $feature.Z_OUV
newGeom['hasZ'] = true
var testGeom = Geometry(newGeom)
I also needed to add a 'hasZ' attribute to the dictionary for it to create a valid geometry.
