Arcade in Attribute Rules Error
3645
7
03-21-2022 11:27 AM
JorgeKappa
Trying to log edits to a layer to a table. It works with some fields, it fails with others with the following error:
Here's my code:
Any clues?
TIA
4 Solutions
JohannesLindner
I get this error if I supply wrong field names. In your case, Arcade could not find the field "serial" in "VPS_BFP_FAIL_2022".
Have a great day!
Johannes
JorgeKappa
Strange, because it's all there, alias properly spelled, field name brought in from the expression builder, not typed. Only three fields work. The rest throw the out of index error except OBJECTID and GlobalID throw the field not editable error.
JohannesLindner
See, there's your problem. You need the real field names, not the aliases.
Have a great day!
Johannes
JohannesLindner
Currently, Attribute Rules don't work in ArcGIS Online, only in Pro and Portal.
Go lend your support to this very popular idea:
Support for Attribute rules in ArcGIS Online - Esri Community
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
JorgeKappa
JohannesLindner
Have a great day!
Johannes
JorgeKappa
Bingo!
JorgeKappa
Johannes, everything works well in Pro desktop. Then I publish the weblayer and the table to AGOL, but when I edit there, nothing gets written to the table. What could be happening there?
JohannesLindner
Have a great day!
Johannes
JorgeKappa
I'd swear I read somewhere that if you upload the .gdb with the layer and the table it would work.
