Combine Multiple Attribute Intersects in one Rule
1516
01-07-2021 08:11 AM
Status: Open
sjet1010
Combining multiple intersect rules into one rule. I have three different point layers for our Stormwater Infrastructure. I have a single line layer that I am writing the rule in. Below is the code I wrote to try to update a field based on intersect and it does not work.
//The attribute rule is setup to pull a field value from a 'upstream' layer.
//This generates the geometry of the line layer
Var g = Geometry($feature);
//The variable generates the start point of the line
Var toPointGeom = g.paths[0][0];
//The variable calls out the point layer and a specific field with no need to return
Var fsPoint =FeatureSetByName($datastore, "GISProduction_10_7_1.SDE.D_Aprons",['FACILITYID']);
Var fsPoint2 =FeatureSetByName($datastore, "GISProduction_10_7_1.SDE.D_Manholes", ['FACILITYID']);
Var fsPoint3 =FeatureSetByName($datastore, "GISProduction_10_7_1.SDE.D_Control_Structure", ['FACILITYID'])
//Selects the first line endpoint that intersects the point
Var toPoint = (Intersects(fsPoint , toPointGeom) )
Var toPoint2 = (Intersects(fsPoint2 ,toPointGeom) )
Var toPoint3 = (Intersects(fsPoint3 ,toPointGeom) )
//The script reads if the Intersect return value is null show '-1', otherwise return the toPoint fsPoint FacilityID
If(toPoint > null){
return toPoint.FACILITYID}
else if (toPoint == null && toPoint2 > null){
return toPoint2.FACILITYID}
else if (toPoint == null && toPoint2 == null && toPoint3 > null){
return toPoint3.FACILITYID}
else{
return -1}
1 Comment
GISUSER6
Hello @sjet1010 ,
I also had been trying to combine all of these intersects into one attribute rule for our stormwater dataset but was unsuccessful in making one rule. Instead I had to make six separate rules for my intersecting features (storm manhole, inlet, and Intake / Outfall points). Three for the "FromPoint" rules and three for the "ToPoint" Rules. Below are examples for the attribute rules just for to and from manholes.
From Manhole Attribute Rule:
var g = Geometry($feature);
var fromPointGeometry = g.paths[0][0];
var stMH =FeatureSetByName($datastore, "stManhole", ["FACILITYID"], false);
var fromPoint = First(Intersects(stMH, fromPointGeometry )  )
if (fromPoint != null){
return fromPoint.FACILITYID;
} else {
// do nothing
To Manhole Attribute Rule:
var toPointGeometry = g.paths[-1][-1];
var toPoint = First(Intersects(stMH, toPointGeometry )  )
if (toPoint != null){
return toPoint.FACILITYID;
} else {
// do nothing
This was the order of the attribute rules I used:
1. From Manhole
2. From Inlet
3. From Intake / Outfall
4. To Manhole
5. To Inlet
6. To Intake / Outfall
Hope this helps some!
