Markup tools no longer work in custom ArcReader 10 app
3436
11-23-2010 11:39 AM
JohnHarney
I have a custom arcreader application that includes some of the markup tools (esriARToolMarkupPenThin, esriARToolMarkupPenMedium, etc.) (see example code below), but they no longer work after I upgraded my project to ArcReader 10 and Visual Studio Pro 2010...  Any ideas to fix the problem?
private void mnuPenThin_Click(object sender, EventArgs e)
            tBarZoomInOut.Pushed = false;
            tBarZoomInBtn.Pushed = false;
            tBarZoomOutBtn.Pushed = false;
            tBarPanBtn.Pushed = false;
            tBarIdentifyBtn.Pushed = false;
            tBarHyperlinkBtn.Pushed = false;
            tBarMeasureBtn.Pushed = false;
            tBarZoomInPage.Pushed = false;
            tBarZoomOutPage.Pushed = false;
            tBarPanPage.Pushed = false;
            mnuPenThin.Checked = true;
            mnuPenMedium.Checked = false;
            mnuPenThick.Checked = false;
            mnuHighBlue.Checked = false;
            mnuHighGreen.Checked = false;
            mnuHighYellow.Checked = false;
            mnuEraseSm.Checked = false;
            mnuEraseMe.Checked = false;
            mnuEraseLa.Checked = false;
            mnuEraseSt.Checked = false;
            CurrentArcReader.CurrentARTool = esriARTool.esriARToolMarkupPenThin;
            StatusBar1.Panels[0].Text = "Current Tool: Thin Markup Pen";
AntonSeiler
Do you have found any solution?
I have the same problem.
Anton
JohnHarney
No such luck...I even tried it with ArcReader 10.1, but still did not work. Let me know if you come across something that works, though. Thanks.
ÉricGosselin
The problem seem related to a known issue by Esri Inc:
NIM088941
http://support.esri.com/en/bugs/nimbus/TklNMDg4OTQx
