Map Properties General Tab Filename
1639
01-25-2011 01:59 PM
TedCronin
From within the General Tab, if the filename is referencing a path on the network, the path can be quite long and thus I am seeing the pmf name get cut off.  Is there anyway to make this a double line to show the name of the file rather than a single line to fix this issue?
