Identify command problem
4876
03-25-2015 07:27 AM
JimSlonaker
When I right click on a feature in the table of contents and use the FIND command. I am able to search for that specific item in the table. However when I right click on the selected item in the search results area and try to use the IDENTIFY command. It flashes the window, then disappears. It is not behind another window or on a second monitor. This only happens when going through the table of contents. Using the FIND command in the toolbar and following the same process, it works correctly.
This is Arc Reader version 10.1 and running on a 32 bit operating system under Window 7.
