Custom ArcReader Spatial Query + other side questions :-)
2458
08-09-2012 05:10 AM
JanuszStozek1
Hi Everyone,
I have a two fold question regards to the spatial query functionality of the Custom ArcReader I have built. I'm using visual express 2010 with vb.net (3.5 .net framework) on a win 7 machine and I was able to get the spatial query with datagridview to work. At the moment when I go to the data view that I want the spatial query obtain and select spatial query button. It will generate 1 record per feature. So if I have 80 or 400 records to cycle through it will be a tedious task. How can I group them logically?
Is there a way, when I use the spatial query to select a specific layer (right now it cycles through every layer it sees) on parcel layer (or select parcel layer that contained 20 parcels id) and it populates 20 records into a datagrid at a time instead of 1 records out of 20 records for that layer?
I believe it can be done I just not seeing how I can loop through that layer of interest. Anyone has a code or custom app that does this trick? I seen the attribute, spatial, map tools and other sources even spent hours on Google and couldn't find any samples)
Other side questions:
1) Layer List - Transparency/swap layer - how can I set the transparency and swap layers?
2) Highlight  tool - How can I select a red marker, thickness and do markings. I couldn't get that to work.
3) Screen size - how can I through programming can re-size screen size on other machines automatically without resizing the custom app for every individual computer screen?
4) Map scale - how do I code to change the scale?
5) Status bar at the bottom of the AxArcReader viewer showing the lat/long as well as page size in inches?
6) Bookmark - How exactly does it work? I can't figure out the trick behind it.
Any help would be greatly appreciated. Willing to trade other code solutions for any code that I can't figure out. Especially for the Spatial Query problem.
Thank you,
Janusz
JanuszStozek1
Got Spatial Query problem figured out...
I was wondering about if anyone had those side questions figured out...
Thanks
JanuszStozek1
I solved other issues and been stuck on those questions. I'm looking for vb.net code samples that can do these following things..
1) Layer List - Transparency/swap layer - how can I set the transparency and swap layers? - I can't find the code.
2) Ink/Highlight tool - How can I select a red marker, thickness and do markings. I couldn't get that to work.
Any guidance or help me steer in the right direction..
Thanks for reading,
Janusz
