ArcReader & adding links to documents (.doc or .pdf)
4595
04-11-2010 06:40 AM
AllisonJ
I have just started publishing maps with ArcPublisher and would like to know if it is possible to add links to the map file displayed in ArcReader?
I am trying to create a map that shows points or polygons and gives the user the option to link to an outside document, - such as in .doc or .pdf format when they identify a place on the map where they would like to get more information.
This would save me from entering loads of attributes!
Thanks for any help,
JustinRichardson
As long as you have a valid directory path the hyperlinking should work.  You could create a table with all of the hyperlinks and a field to link on, then in ArcMap create a join or relate from the layer to this new table.  After you re-publish the document the hyperlinks will show up in the joined table.
AllisonJ
Thanks!  (it works!)
I know that was a kind of basic question!  Still learning about Arc...
KeeraPullman
Thanks!  (it works!)
Any chance you could post a "how to" doc?
