Writing to dbf file and clearing form fields
3259
7
11-11-2010 08:07 PM
CharlesHuxtable
Hi, I'm developing a subform for vegetation data collection in which, following completion of the subform, I want to write to a dbf file and then clear all fields in the subform in preparation for entering another record. (I have another sub which I use for the last record entered which writes to dbf and closes the subform). I can get the data written to the dbf file OK, and can enter subsequent records OK which again writes to the dbf file, however it won't clear the form.
Basically, I the subform is called "Plot Disturbance" into which data is entered in fields via combo boxes  a text box. I then have a button which, when clicked, calls up a Sub called "WritetoSubFormPlotDist". This reads the subform field contents into dbf fields called "OID" (a reference to the site number), "Disturbance Type", "Severity", Age" and "Observed evidence". Because there may be a number of disturbances (records) at each site, I then want to enter the next disturbance type using the same subform and it would be very useful if the form cleared between record exports.
The text I am using is as follows:
Sub WritetoSubFormPlotDist
   Set page = editform.pages.item("PgPlotDist")
   Dim myRS
   Set myRS = Application.CreateAppObject("RecordSet")
   'open the Plot Disturbance DBF-file
   myRS.Open "P:\Work\SSD\Users\Huxtac\ArcPad Stuff\Veg_16\Plot_DistOut.dbf",2
   myRS.AddNew 'adds a new record
   myRS.Fields("OID").Value = layer.Forms("EDITFORM").Pages("General1").Controls("OID")
   myRS.Fields("DIST_TYPE").Value = layer.Forms("FrmPlotDist").Pages("PgPlotDist").Controls("CboDistType")
   myRS.Fields("SEVERITY").Value = layer.Forms("FrmPlotDist").Pages("PgPlotDist").Controls("CboSevCode")
   myRS.Fields("AGE").Value = layer.Forms("FrmPlotDist").Pages("PgPlotDist").Controls("CboAgeCode")
   myRS.Fields("OBS_EVID").Value = layer.Forms("FrmPlotDist").Pages("PgPlotDist").Controls("EdtObsEvid")
   myRS.Update 'saves information to the recordset Land Use DBF-file
   myRS.Close
   Set myRS = Nothing
   Set page = editform.pages.item("PgPlotDist").Clear
End Sub
Any ideas - I've spent several days on this and it's driving me crazy! I thought that "MyRS.Clear" might work, but no!!
Charles
Tags (3)
RolfBroch
Hi Charles, the page object does not have a clear request. You have to clear your controls manually by for example calling a sub like the one below by replacing the statement
with
Call ClearControls(page)
Sub ClearControls(byRef pPage)
  Dim pControl
  For each pControl in pPage.Controls
    If pControl.Type = "COMBOBOX" Or pControl.Type = "LISTBOX" Then
      pControl.Clear
    ElseIf pControl.Type = "EDIT" Then
      pControl.Value = ""
    End If
  Set pControl = Nothing
End Sub
Rolf
PS, I did not check to see if the code above works (but is should)
CharlesHuxtable
Hi Rolf, thanks for your help with this, however I tried what you suggested but couldn't get it to work - I may be doing something wrong. Just to clarify:
1. Do I take your meaning that I need to call a separate Sub to clear the form, rather than a sub operating within the Sub "WritetoSubFormPlotDist", ie I would add a button in my form which,when clicked, would call the sub to clear the form? If so, should the Sub be called "ClearControls(page)" or "ClearControls(byRefpPage)"?
2. Should I use the "pPage" or substitute the name of my form page, ie. "PgPlotDist"?
I'm not experienced with VB, so please excuse my poor understanding!
RolfBroch
Hi again. Sorry for not being clearer. You can add the following code
Dim pControl
For each pControl in page.Controls
    pControl.Clear
    pControl.Value = ""
  End If
into your own routine instead of your statement
Using a subroutine for this was only if you needed to do this several places in your code.
Rolf
CharlesHuxtable
Hi Rolf, thanks for your help. I got it to work with the code you suggested. The only problem was that, after clearing the form, the drop down lists did not appear when I tried to enter the next record. Thus it appeared that the "clear" command somehow removed the "combobox" function from each field in the form. The code is as follows:
'Dim myRS
myRS.Close
Set myRS = Nothing
Dim pControl
For each pControl in layer.Forms("FrmPlotDist").Pages("PgPlotDist").Controls
       pControl.Clear
       pControl.Value = ""
     End If
End Sub
Is there a way to clear the form without removing the combobox drop-down lists?
Charles
CharlesHuxtable
Hi Rolf,
Thanks again for your help. I got it to work with the code below as you suggested. I was able to fill out the form and click an "Add New" button, which calls the subroutine "WritetoSubFormPlotDist", which writes the data to a dbf file and clears the form for the next entry, which it did successfully. The only problem was, when I tried to enter the next record, the drop down lists had disappeaerd from the comboboxes. Any ideas?? Charles
'Dim myRS
myRS.Close
Set myRS = Nothing
Dim pControl
        pControl.Clear
        pControl.Value = ""
      End If
End Sub
RolfBroch
Clearing a combobox will remove the listvalues. If you only want to "clear" the entry, you have to write
pControl.ListIndex = -1 instead of the pControl.Clear statement
Rolf
CharlesHuxtable
Thanks Rolf - all working now
Charles
