auto populate a field from another
4254
6
11-10-2010 05:50 AM
markfarina
What is the best way to auto-populate a text box with the value from a text box on the previous tab??? Is this possible?
Please see attached picture.  In this example, the user would populate the bottom depth of a soil horizon and when he/she tabs over to the next page...the horizon top depth is auto populated from the bottom depth on the previous tab.
APL from H1 tab:
<LABEL name="LABEL29.5" caption="Depths" x="50" y="3" width="35" height="12" tooltip=""/>
<EDIT name="H1TDEPTH" field="H1TDEPTH" x="77" y="2" width="18" height="12" border="true" tabstop="true" tooltip=""/>
<LABEL name="LABEL29" caption="-" x="95" y="3" width="10" height="12" tooltip=""/>
<LABEL name="LABEL29.7" caption="" x="1" y="30" width="45" height="12" tooltip=""/>
<EDIT name="H1BDEPTH" field="H1BDEPTH" x="102" y="2" width="18" height="12" border="true" tabstop="true" tooltip=""/>
Tags (3)
StevenRehbaum
Munsell soil colors huh?  I understand what you mean, but is it essential?  I believe it's possible to do.  Ahhh...Munsell colors take me back.  Good luck.
RolfBroch
Usually a control can only get assigned values, when the page to which the control belongs, is active.
You therefore need to write a script that triggers with the page's onsetactive event. This script should fill the editboxes by reading the values from the previous page.
Rolf
IvanKautter
For the onsetactive event for page H2
Dim obj // creates object
Set obj = ThisEvent.Object.Parent // passes object reference for the parent of the page i.e the form
If Not obj.Mode = 1 Then //will not run code if form is pulled up by the identify tool
Dim pPageH1, pPageH2  // creates page variable
Set pPageH1 = ThisEvent.Layer.Forms("EDITFORM").Pages("H1") //sets object reference for page H1
Set pPageH2 = ThisEvent.Layer.Forms("EDITFORM").Pages("H2") //sets object reference for page H2
pPageH2.Controls("H2TDEPTH").Value = pPageH1.Controls("H1BDEPTH").Value //takes the value from one control and puts it in the other
End If
That's it.
markfarina
I am still learning this and am really stuggling with some of the basic concepts here...
How do I create an onsetactive event for page2 of my form?
I tried inserting....onsetactive="WriteToH2BDepth".... into line one of my form APL below and
Sub WriteToH2Depth 'script from Ivan" End Sub....into the VBS
This didn't work though...Am I on the right track?
Here my APL for H2
<PAGE name="PAGE5" caption="H2" backgroundcolor="white">
<LABEL name="LABEL29" caption="H2" x="3" y="3" width="18" height="12" tooltip=""/>
<COMBOBOX name="H2" field="H2" x="16" y="2" width="30" height="12" border="true" tabstop="true" tooltip="" limittolist="false">
<LISTITEM value="Oa" text="Oa"/>
<LISTITEM value="Oe" text="Oe"/>
</COMBOBOX>
<EDIT name="H2TDEPTH" field="H2TDEPTH" x="77" y="2" width="18" height="12" border="true" tabstop="true" tooltip=""/>
<EDIT name="H2BDEPTH" field="H2BDEPTH" x="102" y="2" width="18" height="12" border="true" tabstop="true" tooltip=""/>
<LABEL name="LABEL28.5" caption="Texture" x="1" y="19" width="35" height="12" tooltip=""/>
<EDIT name="H2Texture" field="H2Texture" x="30" y="19" width="40" height="12" border="true" tabstop="true" tooltip=""/>
<LABEL name="LABEL29.6" caption="Color" x="1" y="77" width="35" height="12" tooltip=""/>
<EDIT name="H2COLOR" field="H2COLOR" x="21" y="77" width="40" height="12" border="true" tabstop="true" tooltip=""/><LABEL name="LABEL29.9" caption="Note" x="64" y="77" width="25" height="12" tooltip=""/>
<EDIT name="H2NOTE" field="H2NOTE" x="83" y="77" width="40" height="12" border="true" tabstop="true" tooltip=""/>
<BUTTON name="cmdAddB1" x="3" y="92" width="23" height="10" onclick="Call drawto10yr" caption="10YR " tabstop="true" alignment="center"/>....................................etc
RolfBroch
You should be on the rigth track.
If you create a Sub out of Ivan's code and add onsetactive="Call WriteToH2BDepth()" as in the following example
<PAGE page="page2" onsetactive="Call WriteToH2BDepth()" ...
ArcPad will execute the script when the page is set active.
I like to write "Call WriteToH2BDepth()" but ="WriteToH2BDepth" should work as well.
I did notice though, that there was no page2 or onsetactive in your apl for H2 below.
Rolf
markfarina
Thanks, I finally got the onsetactive to work!
My mistake was that I did not correctly define (page="page5") in the apl.
Original,
<PAGE name="PAGE5" caption="H2" backgroundcolor="white" onsetactive="Call Ivans code">
Corrected,
<PAGE name="PAGE5" caption="H2" page="page5" backgroundcolor="white" onsetactive="Call Ivans code">
Thanks to everyone.
