Using ArcPad with Camera Function
2106
05-25-2010 12:48 PM
DavidLigocki
Hi there,
I am running ArcPad 7 on a MobileDemand T7000 and I would like to tag photos to a specific location using GPS. When I try to access the camera through ArcPad there is a window called "AVICamera" that pops up and it says "Unable to connect to driver".
Does anyone know if there is a resolution to this issue or if I am doing something wrong?
Thank you for any advice,
Regards
Tags (3)
NenadPetrovic
In your ArcPadPrefs.apx file, see if the <CAMERA device="@WMC" is referring to either
@WMC (Windows Mobile Camera), or @HPC (HP Camera). These are the different modules that you can use as camera drivers and the DLLs are stored on the device under \Program Files\ArcPad\Modules.
For more info, see http://webhelp.esri.com/arcpad/8.0/userguide/index.htm#capture_devices/digital_camera/concept_camera... though I have also had a few devices on trial which could not utilise the device default camera.
