Synchronization problems in Arcpad
2611
09-25-2012 06:56 AM
GustavoBediaga
I'm having problems when synchronizing ArcPAD with Arcgis Server.
I published data using Author Project for Arcgis Server.
Three of the 20 layers were added by Check Out Data For Disconnected Editing: a polygon, a line and a point layer.
I published the service in Arcgis Server using the Arcpad extension, just like the Arcpad help file indicates.
My problem is in the synchronization process.
When I add a new feature in the Arcpad map (i. e. a polygon), then synchronize, it adds the new polygon in the Geodatabase file.
When I synchronize data in another computer, the polygon shows up.
When I delete any feature in the Arcpad map, and synchronize, it also deletes the feature in the Geodatabase file.
But when I synchronize data in another computer, it does not delete the feature in the Arcpad map.
It happens to any feature I delete. I expect that everytime I use the Synchronization tool it compares the Arcpad map data with the Geodatabase file and proceeds the changes that turns the Arcpad map exactly the same as the geodatabase file, adding the new features, and deleting the non-existing ones.
I am using Arcpad 10.0.4, ArcMap 9.3.
Arcgis Server 10.0.
Anyone knows how to solve it?
Gustavo
Tags (3)
