Track log as polygon
1170
08-31-2012 05:14 PM
RandallClark1
Is there anyway in ArcPad, ArcGIS mobile or terrasync to show a tracklog as polygon? or to give it a width to represent that actual
area that is being covered by our sensor?
Tags (3)
JuanLuera
Hola Randall,
In reviewing your questions on the ArcPad side. As you can see below from the ArcPad Help documentation I have provide you with, this will only record as point features into a shapefile. Please let us know if you have any further questions or comments. Gracias, Randall!
The GPS Tracklog
The GPS Tracklog in ArcPad is stored in a shapefile format. The GPS Tracklog can be started or activated when the GPS is active. ArcPad automatically records each GPS position it receives as a point feature in the GPS Tracklog shapefile, as long as the GPS Tracklog is running and the GPS is active.
http://help.arcgis.com/en/arcpad/10.0/help/index.html#//00s100000100000000
JuanLuera
Hola Randall,
In reviewing your questions on the ArcGIS Mobile side. I have looked into the options of Mobile and the ArcGIS Mobile Help, and currently there is not tracklog option within mobile. Please let us know if you have any further questions or comments. Gracias, Randall!
