Symbology Scaling
495
02-19-2011 07:49 AM
NickBirch
How do i scale symbols so that they are in scale with the map using data such as height or spread from survey data?
Tags (3)
DeniseKing
Hi Nick,
If working with scale-dependent symbology in ArcPad, you can specify the minimum and maximum display scales for a layer's symbology via Symbology Properties dialog. You can also set minimum and maximum display scales for an entire layer and for  the labels of a layer. See the ArcPad Reference Guide for more  information.
[ATTACH=CONFIG]4949[/ATTACH]
Cheers,
Denise
