ArcPad Start-Up Problem
2804
02-18-2011 10:43 AM
by Anonymous User
Not applicable
Original User: rdg129
I am getting the following error when I load up ArcPad 10 sp1 on my GeoXMs and my PC.
Help?
Tags (4)
by Anonymous User
Not applicable
Original User: jason.tipton.gis
Try reloading Sql Server Compact. It's under ArcPad Deployment Manager. Make sure that it says successful.
JasonTipton
Also, from my experience, to get SQL to load correctly, you must have the Microsoft Mobile Sync Center connected and running.
by Anonymous User
Not applicable
Original User: Denise62
In addition to Jason's comments be sure to install all 3 separate components that  install during the 'Install SQLce for Windows Mobile' procedure. After each  SQLce component is installed, the mobile device is rebooted to continue with the  installation process.
[INDENT]* Microsoft SQL Server 2005 Compact Edition -  Core
* Microsoft SQL Server 2005 Compact Edition - Replica
* Microsoft SQL  Server 2005 Compact Edition - Dev
[/INDENT]I recommend re-deploying the SQLce  components to your mobile device through ArcPad Deployment  Manager.
Cheers,
Denise
Ryan_Galbraith
That worked perfectly.  Thanx to ALL!
No warning error!
