Should I Abandon My Efforts to Use ArcPad?
969
09-18-2013 11:38 AM
NickJames
Hello All,
I have used VBA code to automate the check-out process for ArcPad in ArcMap.  There are additional procedures that I have been able to translate to VB.Net, but I cannot figure out how to upgrade the attached code. I have googled until my googler is blue.  Apparently, the IArcPadExtension has been eliminated and nothing comparable has been offered in its place.  I would like to keep this project in ArcPad, but if I must, I will figure out how to migrate it into ArcGIS for Mobile Devices.  I am trying to replace my old vba functionality with an ArcMap Add-In.
Thanks for any input,
Nick
PS: I wouldn't rule out my poor coding skills or my lack of focus!
Public Sub CopyoutCheckout() 'On Error GoTo ErrorHandler     '++ get a reference to the ArcPad extension     Dim pArcPadExtension As IArcPadExtension     Dim pID As New UID     pID = "editorExt.ArcPadExtension"     Set pArcPadExtension = Application.FindExtensionByCLSID(pID)     '++ ArcPad xfer error vars     Dim lErrorNum As Long     Dim sErrorDesc As String          '++ ArcPad transaction/xfer vars     Dim pAPTransaction As IArcPadTransaction     Set pAPTransaction = pArcPadExtension   'QI     Dim pArcPadXfer As IArcPadDataTransfer          '++ flag to know if any layers are exported for ArcPad     Dim bExported As Boolean          '++ set the output folder     Dim sOutputFolder As String         If frmSelectHood.chkThru = True Then             sOutputFolder = "\\coddat04\VACPic\VL Pictures " _                     & Format(Date, "yyyy") & "\Thoroughfare_" & Format(Date, "yyyymmdd")         Else             sOutputFolder = "\\coddat04\VACPic\VL Pictures " _                     & Format(Date, "yyyy") & "\" & frmSelectHood.cboHood.value _                     & "_" & Format(Date, "yyyymmdd")             'sOutputFolder = "C:\Temp\testDataForArcPad"         End If          '++ set edit form size to 1/4 VGA size     Dim iFormX As Long, iFormY As Long     iFormX = 130     iFormY = 130     pAPTransaction.SetFormSize iFormX, iFormY          '++ get an IBasicMap ptr to the focus map     Dim pMxDoc As IMxDocument     Dim pMap As IMap, pBasicMap As IBasicMap     Set pMxDoc = ThisDocument     Set pMap = pMxDoc.FocusMap     Set pBasicMap = pMap             '++ get the current view extent     Dim pActiveView As IActiveView     Dim pExtentEnv As IEnvelope     Set pActiveView = pMap     Set pExtentEnv = pActiveView.Extent          '++  spatial filter for checkout/copyout extent     Dim pSpatialFilter As ISpatialFilter     Set pSpatialFilter = New SpatialFilter          '++ layer definition query     Dim pFtrLayerDef As IFeatureLayerDefinition     Dim pQueryFilter As IQueryFilter     Set pQueryFilter = New QueryFilter          '++ get checkout name     Dim sCheckoutName         If frmSelectHood.chkThru = True Then             sCheckoutName = InputBox("Please type the checkout name for this session.", _                              "Checkout Name?", "Thoroughfare_" & Format(Date, "yyyymmdd"))         Else             sCheckoutName = InputBox("Please type the checkout name for this session.", _                              "Checkout Name?", frmSelectHood.cboHood.value _                             & "_" & Format(Date, "yyyymmdd"))             'ToDo: add code to stop the rest of the code             'from running if Sub is Exited             If ("" = sCheckoutName) Then Exit Sub         End If     '++ create ArcPad data xfer session     Set pArcPadXfer = pAPTransaction.CreateDataTransferSession(True, pBasicMap, sOutputFolder)     Dim sCurrOutputName As String '<--(((---     'sCurrOutputName = frmSelectHood.cboHood.value          '++ first, handle all IGeoFeatureLayer layers     pID = "{E156D7E5-22AF-11D3-9F99-00C04F6BC78E}"  'IID for IGeoFeatureLayer     Dim pEnumLayer As IEnumLayer     Set pEnumLayer = pMap.Layers(pID, True)     If Not pEnumLayer Is Nothing Then         Dim pLayer As ILayer         Dim pFtrLayer As IFeatureLayer         Dim pFClass As IFeatureClass         Dim pDataset As IDataset         Dim pSelSet As ISelectionSet         pEnumLayer.Reset         Set pLayer = pEnumLayer.Next         Do While Not pLayer Is Nothing             '++ get current display extent             Set pFtrLayer = pLayer  'QI             With pSpatialFilter                 Set .Geometry = pExtentEnv                 .GeometryField = pFtrLayer.FeatureClass.ShapeFieldName                 .SpatialRel = esriSpatialRelIntersects             End With             '++ get layer definition query              '------------------------------               'Create the query filter ''''    If frmSelectHood.chkThru = True Then ''''        Set pQueryFilter = New QueryFilter ''''        pQueryFilter.WhereClause = "SType = 'Thoroughfare'" ''''    Else ''''        Set pQueryFilter = New QueryFilter ''''        pQueryFilter.WhereClause = "Neighborhood = '" & frmSelectHood.cboHood.value & "'" ''''   End If '-----------------------                                       Set pFtrLayerDef = pFtrLayer    'QI             Dim selecteditem As String                 If frmSelectHood.chkThru = True Then                     selecteditem = frmSelectHood.chkThru.value                     pQueryFilter.WhereClause = "SType = 'Thoroughfare'"                 Else                     selecteditem = frmSelectHood.cboHood.value                     pQueryFilter.WhereClause = "Neighborhood = '" & selecteditem & "'"                     'pQueryFilter.WhereClause =  'pFtrLayerDef.DefinitionExpression                 End If            '++ get selection set             Set pFClass = pFtrLayer.FeatureClass             Set pSelSet = pFClass.Select(pSpatialFilter, esriSelectionTypeIDSet, esriSelectionOptionNormal, Nothing)             '++ give option to checkout or copyout gdb, copyout all others             Set pDataset = pFClass  'QI             Select Case pDataset.Category                                  Case "Personal Geodatabase Feature Class", "SDE Feature Class":                     If MsgBox("Yes to Checkout, No to Copyout.", vbYesNo, pFtrLayer.Name) = vbYes Then                         pArcPadXfer.CheckoutFeatures pLayer, pQueryFilter, pSelSet, True, False, sCheckoutName, "", sCurrOutputName                     Else                         pArcPadXfer.CopyoutFeatures pLayer, pQueryFilter, pSelSet, True, True, "", sCurrOutputName                     End If                 Case Else:                     pArcPadXfer.CopyoutFeatures pLayer, pQueryFilter, pSelSet, True, True, "", sCurrOutputName                              End Select             '++ report success or error             Select Case lErrorNum                 Case 0:                     MsgBox sCurrOutputName & " created.", vbInformation, pFtrLayer.Name                     bExported = True                 Case Else:                     MsgBox lErrorNum, vbExclamation, pFtrLayer.Name & " not exported"                     lErrorNum = 0             End Select             Set pLayer = pEnumLayer.Next         Loop     End If          '++ next, copyout IRasterLayer layers     pID = "{D02371C7-35F7-11D2-B1F2-00C04F8EDEFF}"  'IID for IRasterLayer     Set pEnumLayer = pMap.Layers(pID, True)     If Not pEnumLayer Is Nothing Then         pEnumLayer.Reset         Set pLayer = pEnumLayer.Next         Do While Not pLayer Is Nothing             pArcPadXfer.CopyoutRaster pLayer, pExtentEnv, sCurrOutputName             '++ report success or error             Select Case lErrorNum                 Case 0:                     MsgBox sCurrOutputName & " created.", vbInformation, pLayer.Name                     bExported = True                 Case Else:                     MsgBox sErrorDesc, vbExclamation, pLayer.Name & " not created"                     lErrorNum = 0             End Select             Set pLayer = pEnumLayer.Next         Loop     End If          '++ end the transaction     pArcPadXfer.Flush     If bExported Then         MsgBox "Operation complete.", vbInformation, sCheckoutName     Else         MsgBox "No layers were exported for ArcPad.", vbExclamation, sCheckoutName     End If          Exit Sub ErrorHandler:     Select Case Err.Number         '++ handle ArcPad xfer errors         Case -2147221247 To -2147221242:             lErrorNum = Err.Number             sErrorDesc = Err.Description             Resume Next         '++ handle E_FAIL; likely cause is use of IMap::Layers when no layers match the IID         Case -2147467259:             Set pEnumLayer = Nothing             Resume Next         '++ handle all other errors         Case Else:              MsgBox Err.Number & vbCrLf & Err.Description, vbCritical, "Error"     End Select End Sub
Tags (3)
NickJames
Apparently the answer is yes, abandon ArcPad...
NickJames
