Script constant for form mode?
3224
05-12-2012 02:41 AM
SteveFitzgerald
I'm sure I've seen somewhere a constant for Arcpad's EditForm modes - something like 'apModeEdit', etc...
I searched the documentation but couldn't find anything.
No matter how much scripting I do I can never remember reliably which mode is which and a constant would make code so much easier to read.
Any one?
Steve
Tags (3)
KyleBelott
Take a look at the Customizing ArcPad Help file under the ArcPad programs folder, i.e. "C:\Program Files (x86)\ArcGIS\ArcPad10.0\Developer\Help\ArcPadStudio.chm".
In the contents tab, locate "ArcPad Object Model Reference", then "Form Object", and Mode property.
Is that what you're looking for?
Hope this helps,
Kyle
SteveFitzgerald
Kyle,
Thanks for taking the time.
I forgot to mention I'm still on Arcpad 8.
Your prompt did however lead me to double (make that triple) check the object model and the help files...
Tantalizingly, there is a help file entry called 'mode constants' but it relates to the File object not the Form.
Would you be able to cut 'n paste to the forum?
Regards,
Steve
KyleBelott
Steve,
Here's the Mode property page from the customizing help in ArcPad 10.
[ATTACH=CONFIG]14292[/ATTACH]
SteveFitzgerald
Kyle,
Sorry - you misunderstood what I was after but thanks again for taking the time.
Instead of using "If Map.EditLayer.Forms("EditForm").mode = 2 then..." I would like to use
something like "if Map.EditLayer.Forms("EditForm").mode = apFormEdit then..."
I'm fairly sure there are constants for the form modes but maybe they are not documented.
Or, maybe I dreamt it.
Regards,
Steve
