Retrieve XY Coordinate
2354
08-25-2010 05:49 AM
JayKappy
I have a project that I am creating that I need to get the XY from a point that has just been created.
Example:  THe user adds a new point feature in ArcPAD.  I need to write the XY to varaible...a message box would be fine as well as I woudl be able to write that to a variable eventually.
I am trying this and keep getting 0 for the X value
Any thoughts on how to retrieve the XY....NOTE this is before the feature gets saved...so its a pending XY value
THanks in advance
Dim objRS4, objSelLayer4, objEFPageOneControls4, objEditForm4
Set objSelLayer4 = Map.SelectionLayer
Set objRS4 = objSelLayer4.Records
objRS4.Bookmark = Map.SelectionBookmark
Set objEditForm4 = application.map.layers("Supports").forms("EDITFORM")
MessageBox "The X coord is " & objEditForm4.Fields.Shape.X
Tags (3)
JayKappy
I got this to work but I want my Coordinates in LAt Long....Is there a way to convert these Hennepin County Minnesota Coordiantes to Lat Long
BUT THIS ONLY WORKS on existing points....I cannot get this to work on a new point that was just dropped by the user....Can this be done?
Is there soem point down or point up event that I can use?
Dim objLyr, objRS, pMapPt
'get xy of selected feature
Set objLyr = Application.Map.SelectionLayer
Set objRS = objLyr.Records
objRS.BookMark = Map.SelectionBookmark
Set pMapPt = Application.CreateAppObject("Point")
pMapPt.X = objRS.Fields.Shape.X
pMapPt.Y = objRS.Fields.Shape.Y
objLyr.forms("EDITFORM").Pages("PAGE1").Controls("txtX").value = cstr(pMapPt.X)
objLyr.forms("EDITFORM").Pages("PAGE1").Controls("txtY").value = cstr(pMapPt.Y)
by Anonymous User
Not applicable
Here are afew lines from a tool I have written in the past. This explains populating a field/control with eastings and northings base don whether the user map clicks or uses the GPS. It doesn't answer your question about lat and long, but I'm sure it's possible...
If Application.UserProperties ("AddPoint_ToolUsed")="addpoint" then
  objEFPageOneControls("EASTING").value = FormatNumber(Map.PointerX,2,-2,-2,0)'FormatNumber(Map.PointerX,2)
  objEFPageOneControls("NORTHING").value = FormatNumber(Map.PointerY,2,-2,-2,0)'FormatNumber(Map.PointerY,2)
  Application.UserProperties ("AddPoint_ToolUsed")=""
else
  objEFPageOneControls("EASTING").value = FormatNumber(GPS.X,2,-2,-2,0)'FormatNumber(GPS.X,2)
  objEFPageOneControls("NORTHING").value = FormatNumber(GPS.y,2,-2,-2,0)'FormatNumber(GPS.Y,2)
end if
