Related tables: ArcGIS 9.3.1 and ArcPad 10
817
02-07-2012 07:14 AM
RyanCoghlin
I just got my hands on ArcPad 10 and was excited to have related table forms created by default upon checking out my AXF. However, reading through the literature I now see that this won't be the case since I'm still on ArcPad Data Manager for ArcGIS 9.3. The literature here says that I "can still create custom forms for your related tables with ease, in ArcPad Studio 10". I have not yet been able to figure out how to do so "with ease". Am I missing something or will the workflow still require intensive customization to handle all data validation and SQL statements to update the related table (as with the Riverside developer's sample)?
Tags (3)
TimHopper
Ryan,
When using ArcPad 10 with ArcGIS 9.3 the version 8.0 ArcPad Data Manager is installed.  This version supports related tables.
All you need to do is the following:
1. Create a 'one to one' or 'one to many' relationship class between a feature class and a geodatabase table.
2. Include both the feature class AND the related table in the map document used for checkout.
3. Using the ArcPad Data Manager toolbar, 'Get Data for ArcPad'.
4. Select the action 'Check out for disconnected editing' for your feature class (you will see your related table included next to the feature class name).
5. Complete the check out.
The resulting axf file will contain the feature class and the related table, including the necessary components to make the relationship work.  No additional customization necessary by you.  When you check the axf file back in, all related records will come as well.
Hope this helps.
TimHopper
Ryan,
Hope this helps.
