Recordset.Find method   - Does this work in axf layers?
1774
10-03-2012 11:25 AM
KeithGanzenmuller
I have a point layer in an axf file, I have a reference to the recordset and I am simply trying to use FIND to locate a particular record. The script keeps throwing an "Object doesn't support this method" error.
Is this correct? Does an axf recordset not support Find?
Keith
Tags (3)
ThaiTruong
Yes, RS.Find doesn't work for AXF Feature Layers
ThaiTruong
KeithGanzenmuller
Thanks. I could not find that written anywhere in the help system and there is no differentiation in the OMD for axf and non-axf feature layers. Very frustrating.
ThaiTruong
Here is a workaround for you.  I used Riverside.axf\Parcel from ArcPad Samples for this sample code.
The message box shows the address of APN = 225112008
Set objLayer = Application.Map.Layers("Parcel")
Dim pDS
Set pDS = Application.Map.Layers("Parcel").DataSource
Dim pRS
Set pRS = pDS.Execute("SELECT * FROM PARCEL WHERE APN = 225112008")
If (pRS is Nothing) Then
 MsgBox("No Record Found!")
 Exit Sub
End If
pRS.MoveFirst
Do While Not pRS.EOF
 msgBox(pRS.Fields(3).Name & ": " & pRS.Fields(3).Value & vbnewline & pRS.Fields(5).Name & ": " & pRS.Fields(5).Value)
 pRS.MoveNext
Loop
