Problems using "Find" tool on desktop
2253
02-12-2014 12:20 PM
HannesZiegler1
Has anyone ever had this happen, and how were you able to get around it. When I try to use the find tool in arcpad on the desktop
to query for a specific item, I can't change between tabs (the tabs on the top of the "find" dialogue window) to get to a different
layer or the query item. Whenever I do this, I get this message:
[ATTACH=CONFIG]31379[/ATTACH]
Any explanation for why this happens?
Tags (3)
HannahFerrier
Query Forms (the user interface on the 'Find' Tab) are able to be edited in ArcPad Studio, just like the Edit Forms used for data collection. The message you are seeing occurs when a field on a Query Form has been marked as 'Required' in ArcPad Studio.
To remove this message is as easy as opening your .axf in ArcPad Studio and un-checking the 'Required' box on the OBJECT ID field in your Query Form.
[ATTACH=CONFIG]31428[/ATTACH]
[ATTACH=CONFIG]31429[/ATTACH]
See more about ArcPad Forms here.
Hope this helps,
Hannah 🙂
