Problem with adding new toolbutton
1121
02-13-2014 04:20 AM
JakubPawlak
Is it possible to add new (second) toolbar or just toolbutton in the other place in ArcPad? It means - I want to locate some icons (tools) on the top and some icons on the bottom of screen (not in one toolbar).
I tried add new "toolbutton" in the toolbars in .apx file ina ArcPad Studio (next to MapNavigator and Toolbutton=quickstart) also I added new "toolbars" in confuigure file.
Tags (3)
HannahFerrier
You can add your tools to 2 places:
#1 is the ArcPad Toolbar. Although the entire toolbar can be docked to the bottom or side of your screen - it is THE place for your tools. You are able to build your own toolbar and tools, and then hide the default toolbars, but there is only one toolbar 🙂 See here for more details.
#2 is the Map Navigator. This is the on-map set of tools (zoom in/out, pan and full extent). By default they are use-once navigation tools - but you can customize the Map Navigator to use any other ArcPad tools. See here for more details.
You are not able to create tools in ArcPad outside of these areas.
Hannah 🙂
