How to fix JPG2000 support for ArcPad with ArcMap 10.3.1 and ArcPad Data Manager 10.0
3478
04-18-2016 06:01 AM
ValentinWittich
Since ArcMap 10.3.1 the generated JPG2000 won't work anymore in ArcPad 10.2. I'm using the ArcPad Data Manager 10.0 Extention to convert a MXD-Project for ArcPad.
The problem is that ArcGIS 10.3.1 generates a corrupted *.jpg2.aux.xml file. Did anybody make a similar experience?
I'm using EPSG 9902, I hope that's not the problem. The generated XML file looks like that:
<PAMDataset>
  <Metadata>
    <MDI key="Corder">PCRL</MDI>
  </Metadata>
  <Metadata domain="xml:gml.root-instance">
    <MDI key="&lt;gml">FeatureCollection xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlJP2Profile/1.0.0/gmlJP2Profile.xsd"&gt;
  &lt;gml:boundedBy&gt;
    &lt;gml:Null&gt;withheld&lt;/gml:Null&gt;
  &lt;/gml:boundedBy&gt;
  &lt;gml:featureMember&gt;
    &lt;gml:FeatureCollection&gt;
        &lt;gml:RectifiedGridCoverage dimension="2" gml:id="RGC0001"&gt;
          &lt;gml:rectifiedGridDomain&gt;
            &lt;gml:RectifiedGrid dimension="2"&gt;
        &lt;/gml:RectifiedGridCoverage&gt;
      &lt;/gml:featureMember&gt;
    &lt;/gml:FeatureCollection&gt;
</MDI>
  </Metadata>
  <Metadata domain="xml:CRSDictionary.gml">
    <MDI key="&lt;gml">Dictionary gml:id="CRSU1" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"&gt;
  &lt;gml:dictionaryEntry&gt;
    &lt;gml:ProjectedCRS gml:id="ogrcrs13"&gt;
      &lt;gml:srsName&gt;DHDN_3_Degree_Gauss_Zone_3&lt;/gml:srsName&gt;
      &lt;gml:baseCRS&gt;
    &lt;/gml:ProjectedCRS&gt;
  &lt;/gml:dictionaryEntry&gt;
&lt;/gml:Dictionary&gt;
</MDI>
  </Metadata>
  <Metadata domain="Esri">
    <MDI key="PyramidResamplingType">NEAREST</MDI>
  </Metadata>
  <PAMRasterBand band="1">
    <Histograms>
    </Histograms>
    <Metadata domain="IMAGE_STRUCTURE">
      <MDI key="COMPRESSION">JP2000</MDI>
    </Metadata>
    <Metadata>
      <MDI key="SourceBandIndex">0</MDI>
      <MDI key="STATISTICS_COVARIANCES">2195.994657066516,1948.976467658431,1811.804962385833</MDI>
      <MDI key="STATISTICS_EXCLUDEDVALUES"></MDI>
      <MDI key="STATISTICS_MAXIMUM">255</MDI>
      <MDI key="STATISTICS_MEAN">89,487069317156</MDI>
      <MDI key="STATISTICS_MINIMUM">0</MDI>
      <MDI key="STATISTICS_SKIPFACTORX">1</MDI>
      <MDI key="STATISTICS_SKIPFACTORY">1</MDI>
      <MDI key="STATISTICS_STDDEV">46,861441047694</MDI>
    </Metadata>
  </PAMRasterBand>
  <PAMRasterBand band="2">
  </PAMRasterBand>
</PAMDataset>
One thing is that the less-than sign ( &lt; < ) and the greater-than sign ( &gt; > ) are not correct shown. The other thing is that the NoDataVaue-tags are missing:
<NoDataValue>2.56000000000000E+002</NoDataValue>
Also the whole header is corrupted.
However I was able to repair the XML file manual:
<PAMDataset>
  <Metadata domain="xml:gml.root-instance" format="xml">
    <gml:FeatureCollection xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengeospatial.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlJP2Profile/1.0.0/gmlJP2Profile.xsd">
      <gml:boundedBy>
        <gml:Null>withheld</gml:Null>
      </gml:boundedBy>
      <gml:featureMember>
        <gml:FeatureCollection>
          <gml:featureMember>
            <gml:RectifiedGridCoverage dimension="2" gml:id="RGC0001">
            </gml:RectifiedGridCoverage>
          </gml:featureMember>
        </gml:FeatureCollection>
  </Metadata>
  <Metadata domain="xml:CRSDictionary.gml" format="xml">
    <gml:Dictionary gml:id="CRSU1" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
      <gml:dictionaryEntry>
        <gml:ProjectedCRS gml:id="ogrcrs25">
          <gml:srsName>DHDN_3_Degree_Gauss_Zone_3</gml:srsName>
          <gml:baseCRS>
        </gml:ProjectedCRS>
      </gml:dictionaryEntry>
    </gml:Dictionary>
  </Metadata>
  <Metadata domain="ESRI">
  </Metadata>
    <Histograms>
    </Histograms>
    </Metadata>
    <Metadata>
    </Metadata>
  </PAMRasterBand>
  </PAMRasterBand>
</PAMDataset>
How can I fix that problem permanently?
Updated
Can anybody confirm that this is a bug from ArcMap 10.3?
