Duplicate Polygon and Polyline when insert a vertex
1270
04-27-2013 10:45 AM
MatthieuPette
Hello (I'm french sorry for my bad spelling)
I have a aleatory bug : When I insert a vertex in polygon or polyline shape, sometimes the shape is duplicated.
Do you know this problem ? is there a fix ?
thanks
Matthieu
Tags (3)
GarethWalters
Hi Matthieu,
Could you provide a bit more information?
  • What version of ArcPad are you using?
  • Are you just using out of the box tools?
  • What sort of data are you using SHP or AXF?
Cheers,
Gareth
MatthieuPette
thanks for your response.
We are testing ArcPad 10.2 Beta and 10.0.4 in évaluation. We have a licence of arcpad 7 and we should migrating in few month.
We use SHP because we encounter another bug with AXF import export (a mix of datas in the fields :s) and shp is used in many software.
We had created an applet with custom toolbar but the edit tool are not re-devloped (we have a custom edit form and and 3 tool button with minor functions, just select the edit layer in 3 point layer and show/hide raster)
To precise the bug : We have duplicate polygon in 10.0.4 version but we have delete polygon in 10.2 beta. Only for polygons and polylins we had insert a vertex.
Best regards
Matthieu
