Combo Box Problem
2221
07-27-2011 06:42 PM
SCWONG
I am adding the following information to the Combo Box of a Form using additem on ArcPad 10 and set the
objCtr.ListIndex = 17
objCtr.Value = ???1100 ??? 1730???
In WM6.5, it shows a correct value of ???1100 ??? 1730??? onscreen, however the PC version shows a value of ???1300 ??? 2000???.
For those Combo Boxes with alpha elements, it shows correctly in both PC and WM.
Also, the VBS codes have been executed by ArcPad 6 and 7 and no problem occurred.
How can I solve the problem in ArcPad 10?
Elements
blank                 0
0800 - 1515 1
0815 - 1515 2
0900 - 1200 3
0900 - 1230 4
0900 - 1530 5
0900 - 1600 6
0900 - 1600 7
0900 - 1615 8
0900 - 1700 9
0915 - 1600 10
0930 - 1130 11
0930 - 1530 12
0930 - 1600 13
1000 - 1130 14
1030 - 1730 15
1045 - 1430 16
1100 - 1730 17
1300 - 2000 18
1300 - 2000 19
1300 - 2015 20
_________
SC Wong
Tags (3)
AndrewHansford
I was wondering are you harding coding the values through VB or have you created a list in ArcPAD GUI?
Are you able to show your code for this?
Also i wonder if it would be easier to add the list from the file like txt or dbf, just a thought, or if you are using an AXF file then why not create the table in AXF?
Cheers
objCtr.Value = �??1100 �?? 1730�?�
In WM6.5, it shows a correct value of �??1100 �?? 1730�?� onscreen, however the PC version shows a value of �??1300 �?? 2000�?�.
Elements
blank                 0
0800 - 1515 1
0815 - 1515 2
0900 - 1200 3
0900 - 1230 4
0900 - 1530 5
0900 - 1600 6
0900 - 1600 7
0900 - 1615 8
0900 - 1700 9
0915 - 1600 10
0930 - 1130 11
0930 - 1530 12
0930 - 1600 13
1000 - 1130 14
1030 - 1730 15
1045 - 1430 16
1100 - 1730 17
1300 - 2000 18
1300 - 2000 19
1300 - 2015 20
_________
SC Wong
SCWONG
Hi, Andrew. Thanks for your advice. The application has been developed in 2002 and successfully run on ArcPad 6 and 7. Unfortunately, it appears abnormally in ArcPad 10.0.2 (PC Version only).  I just want to know whether it is a bug of ArcPad.  If affirmative, I do not have to waste my time to refine the program codes.
I observed that it appears on combobox that all items have no alpha char. If I added an item with alpha char, the combobox showed correct value.
SC
Program codes:
Sub SetComboBox(objCtr, mValue, mFieldName, mSQL, mBlank)
Dim condb
Dim objRS
Dim mCount
Dim mListIndex
Dim mData
Set condb = CreateObject(gtxtConnection)
condb.ConnectionString = gstrConn
condb.Open
Set objRS = CreateObject(gtxtRecordset)
objRS.Open mSQL, condb, 1
mCount = 0
mListIndex = -1
mValue = Trim(DefVal(mValue, ""))
If mValue = mBlank Then mListIndex = 0
Call objCtr.Clear
Call objCtr.AddItem(mBlank, mBlank)
Do While (Not objRS.EOF)
   mCount = mCount + 1
   mData  = Trim(DefVal_Str(objRS.Fields(mFieldName).Value, mBlank))
   If (mListIndex < 0) And (mValue = mData) Then mListIndex = mCount
   Call objCtr.AddItem(mData, mData)
   objRS.MoveNext
Loop
If (mListIndex < 0) And (mValue <> mBlank)  Then
   Call objCtr.AddItem(mValue, mValue)
   mListIndex = mCount + 1
End If
objCtr.ListIndex = mListIndex
objCtr.Value = mValue
objRS.Close
Set condb = Nothing
Set objRS = Nothing
End Sub
AndrewHansford
Hi SC,
I had a similar problem with an application that I built in ArcPad 7 (in 2008) and at that stage I did a massive rebuild of the application to incorporate some of the new functionality between 6 and 7.
Unfortunately there appears to be differences in ArcPad 7 and ArcPad 10 (not just isolated to 10.0.2) Were on the device it wasnt calculating my values at the end of my application.
Unfortunately I havent had a chance to investigate this. One would imagine that ESRI has subtly changed something that is causing the error. I would have to say that it is both a bug in the code and the application.
There is no straigh forward check either.
Sorry about this
Regards
Andrew
SC
Program codes:
Dim condb
Dim objRS
Dim mCount
Dim mListIndex
Dim mData
condb.Open
mCount = 0
mListIndex = -1
Call objCtr.Clear
   mCount = mCount + 1
   objRS.MoveNext
Loop
End If
objRS.Close
Set condb = Nothing
Set objRS = Nothing
End Sub
