HELP PLEASE!! Preparing data for GPS-enabled geodatabase
1512
08-01-2011 09:55 AM
MaboMakhubu
Hi, i've just recently started using GPS Analyst with ArcGIS & ArcPad for a Juno SB. Is there anywhere i can get a step-by-step guide on how to prepare the data in order to be able check it out???
It's quite frustrating because i don't know where to start. I've created the personal geodatabse and set the domains but i don't know where to begin with the selectable feature which will be worked on, once out in the field. More especially how to tie up the feature with the domain attributes.
Tags (3)
ZachEdwards
Mabu,
The following link will take you to a useful tutorial that was put together by the geological sciences department at UT Austin: http://www.geo.utexas.edu/courses/371C/Labs/Lab10.htm. If this isn't sufficient, I can send along a step-by-step that a colleague and I put together when I was working in the Geography Department at NMSU.
MaboMakhubu
Hi Zach,
Thnx for the previous link. Please send me the ste-by-step that you and your colleague put together so that i can go through that as well.
ZachEdwards
Hi Zach,
Mabu,
You'll have to provide me with your email address. I cannot upload the .pptx file by itself or zipped. It says it's too big but I know it's not. The .zip file limit is 2MB and the zipped file is 1.2MB.
MaboMakhubu
Zach,
please send it to [email protected]
Thank you so much for your help.
