checkin AXF error
2786
04-17-2014 08:03 AM
MonteJohnson1
HELP!  I've searched everywhere for an answer but no luck so far!
Trying to check in to ArcPad with Trimble GPS Correct, get the following:
An error occurred while importing the file: 80040103
Failed to check in from AXF file
Failed to execute (CheckinAXFFileAndGPScorrectSSF).
I didn't change any settings on anything and now am getting this error when I try to check in two different layers.
I have no problem checking in other things.  Even from the same Dataset, database, etc, and all with the same settings.  I even tried checking out/in on a different Trimble GeoXH and same error when trying to check out these two specific layers.
It can see that I've made changes, but just shows the above error.
Anybody else ever got the same error code as me above?
Thanks!
Tags (3)
DanielWebb2
Hi.  I'm getting the same error and am trying to find solutions.  Did you ever get it to work?
One site said it needs to be in the folder as when it was checked out (which I'm pretty sure it is).  Maybe you know a way to see what the original folder was?
Any suggestions would be useful.  Thanks!
