Change list box to combo box in ArcPad?
3077
02-01-2013 06:09 AM
MarkAndersen1
I have what I hope is a pretty simple question...  I'm putting together an ArcPad map for some data collecting this spring.  When I load the project into ArcPad, everything looks and works fine, with one exception.  The default edit form for entering attributes (to a point shapefile and a related table) is fine, except that one of my attribute columns in the related table is a text field that uses a domain that contains hundreds of 4-letter code.  It's a pain to scroll through these, and it would be much simpler if this were a combo box, so that a user could type the first letter or two, and find the correct entry more quickly.   Is there a way to access the default form in ArcPad Studio, and just change the list box to a combo box?  Or will I have to create a new data entry form?  Also, where is a good place to start reading about customizing forms, etc?  The help files I've looked at so far don't seem particularly helpful on specific questions.
Thanks!
Tags (3)
GarethWalters
Hi Mark,
Currently the combo box does not implement text recoginition to filter a list in ArcPad Forms.  The only solution to this is to write a script to do it.
There are many similar questions to this and it is the No. 3 voted question on Ideas.Esri.com.
Sorry that there is no quick fix at this stage.
Let me know if you want any more information.
Cheers,
Gareth
ValentinWittich
Hi Mark,
I don't know if I'm to late for these field season but the fastest way to change a list box into a combo box is to toggle into the tree view (little red/blue arrows) in ArcPad Studio. Here you can just replace list listbox entries into a combobox:
<LISTBOX name="List_code" tooltip="" x="47" y="15" width="80" height="50" tabstop="true" border="true" defaultvalue="" listtable="" listvaluefield="" listtextfield="" sort="false" field="CODE" hscroll="false">
      <LISTITEM value="1111" text="1111"/>
      <LISTITEM value="2222" text="2222"/>
      <LISTITEM value="3333" text="3333"/>
      <LISTITEM value="4444" text="4444"/>
     </LISTBOX>
into =>
<COMBOBOX name="List_code" tooltip="" x="47" y="15" width="80" height="50" tabstop="true" border="true" defaultvalue="" listtable="" listvaluefield="" listtextfield="" sort="false" field="CODE" hscroll="false"  sip="true" >
     </COMBOBOX>
I hope that's what you were asking for...
Best regards
Valentin
