Cannot check in ArcPad data to ArcMap
4075
08-27-2013 12:28 PM
JasonYoung1
I recently collected data and have come across an issue with checking my data in after waiting 2 hours. When I got to check in the data I receive this message:
Unhandled exception has occurred in a component in your
application. If you click Continue, the application will ignore this error
and attempt to continue.
record 512 not processed.
The details included with the error are as follows:
  ***************Exception*Text***************
 System.Exception:*record*512*not*processed
 ***at*Trimble.MGISSDK.Ssf.SsfBaseReader.a?SsfRecordTypes*A_0,*Byte[]*A_1?
 ***at*Trimble.MGISSDK.Ssf.SsfBaseReader.Read??
 ***at*u.d?String*A_0,*Int32&*A_1?
 ***at*d.h?String*A_0,*IArcPadExchange*A_1,*Dictionary`2*A_2,*Project*A_3,*Int32&*A
 ***at*OfficeApp.AxfCheckInForm.b?Object*A_0,*EventArgs*A_1?
 ***at*System.Windows.Forms.Control.OnClick?EventArgs*e?
 ***at*System.Windows.Forms.Button.OnClick?EventArgs*e?
 ***at*System.Windows.Forms.Button.OnMouseUp?MouseEventArgs*mevent?
 ***at*System.Windows.Forms.Control.WmMouseUp?Message&*m,*MouseButtons*button
 ***at*System.Windows.Forms.Control.WndProc?Message&*m?
 ***at*System.Windows.Forms.ButtonBase.WndProc?Message&*m?
 ***at*System.Windows.Forms.Button.WndProc?Message&*m?
 ***at*System.Windows.Forms.Control.ControlNativeWindow.OnMessage?Message&*m
 ***at*System.Windows.Forms.Control.ControlNativeWindow.WndProc?Message&*m?
 ***at*System.Windows.Forms.NativeWindow.Callback?IntPtr*hWnd,*Int32*msg,*IntPtr*
I've never had an issue checking in data so I'm at a loss as to what I should do. I don't know if this has anything to dow ith it, but when I copy the folder back to my computer the process is extremely slow... 10+ mins. Whereas in the past it only takes 1-2 mins to copy.
Tags (3)
AdamShinal1
Hi Jason,
I came upon this thread after experiencing a similar issue and an almost identical error message when trying to check in a GPS project.  Did you ever figure out what was causing the problem?
Adam
