Can't see Checked Out Data In ArcPad
1378
06-23-2014 12:11 AM
MarkYoung
I have an mxd with a base layer and an editable layer. When I select the the editable layer as checkout for disconnected editing (Using the 'Get Data for ArcPad' button in ArcPad Data Manager extension) it is not added to the ArcPad project - just a 1kb .axf file.
There is also the issue if we open ArcPad 10.2 on our PC we get a SQL server compact initialization error and ArcPad will function with limited functionality - I presume this is the cause of the editable layers not being exported to ArcPad. I did try and go to ArcPad deployment manager and manually tick SQL server compact but no difference.
Any ideas whats stopping the editable layers being copied to ArcPad or anyone had experience of this SQL server compact initialisation error?
Thanks in advance
Mark
Tags (3)
