Auto populate values in related table - PLEASE HELP!
2435
08-14-2011 12:13 PM
MatthewWilson1
I am having some trouble inserting values into a related table in ArcPad 10.  Once an existing facility is selected from the map, I would like to auto populate the related table (DA_FORM) with values from the GIS feature attribute table.  I am not a programmer by any means, so please excuse my ignorance here!
I can select the appropriate values from the GIS feature, but am having trouble executing the SQL statement.  I get an error on the execute SQL line saying, "the column cannot contain null values. [,,,Column Name, Table Name,]"  Here's what I have so far:
(onformload event)
Sub AutoPop
dim objSelLyr, objSelRS, StrFacilNo, StrStructName
set objSelLyr = Application.Map.SelectionLayer
set objSelRS = objSelLyr.Records
objSelRS.Bookmark = Map.SelectionBookmark
'Get values from structure_existing_area layer
StrFacilNo = objSelRS.Fields("facil_no").Value
StrStructName = objSelRS.Fields("structname").Value
msgbox ("Facility # is " & StrFacilNo & ": " & StrStructName)
Dim DS
Dim SQL
Dim Result
'Set data source
Set DS = objSelLyr.DataSource
'Define SQL statement to insert values into table DA_FORM
SQL = "INSERT INTO DA_FORM (facil_no, facil_type) VALUES ('" & StrFacilNo & "', '" & StrStructName & "')"
'Execute SQL command
Result = DS.Execute(SQL)
End Sub
Tags (3)
