ArcPad10 GPS screen elevation info in engineering format instead of full value
3536
07-14-2011 06:52 PM
PatrickMurphy
HI all,
I am running ArcPad10 on an HP211 with a bluetooth GPS.  The position information at the bottom of the screen when I am connected to the GPS shows elevation in engineering format instead of plain old numbers.  For example an elevation of 5,280 is shown as 5.28e 10^3.
How do I get this back to normal.
Pat
Tags (3)
PatrickMurphy
HI all,
Pat
The actual format that is shown on the screen is 5.28e+003 ft.  Is the elevation showing properly on your screen?
RyanAnderson
Not sure what you got going on there but, try to tap on the elevation values you are getting and a menu may pop up with some other values to display.  Much like in the GPS postion window you can click on the values to pull a menu of additional values to read such as PDOP, VDOP EPE etc.
PatrickMurphy
All of the other elevation units were in the same scientific notation.  I have a maintenance agreement with ESRI, and they told me to install the Service Pack 2.  I did that and it sort of fixed it.  Now the elevation is in normal format, but the 4 decimal places overwrite the adjacent coordinates so they are hard to read.  If I go to the additional screens, the Data tab truncates the left side of the elevation.  These are all bugs or incomplete testing glitches.
