Arcpad Studio From On Event Script Help
2725
05-25-2010 03:49 PM
HeathSmith
I'm completely lost and am not even sure how to search for what I want to do. I have a form I created and when I select a certain variable on the form (1 of 2 radio Buttons) I would like for it to then automatically select values in two other combo boxes. Can anyone point me in the right direction.
I've been trying to work with the Even Script for On.Click.
Heath
Tags (3)
RebeccaBleney
Hi
Not sure if I'm the best person to help you, but someone helped me recently with a similar problems.
Just read what the other person told me, don't worry what I said.
http://forums.arcgis.com/threads/4184-using-Arcpad-Studio-to-create-form-for-Arcpad
Wasn't to sure if you were trying just to use  ".additem"  or ".additemfromtable", in the end I had 3 combo boxes working from 3 different databases.
if you are getting errors when you run it, check the line number and look up the error number on the internet.   If you still having problems show some of your coding in you next posting sometime it is just a small thing that will stop it.
Rebecca
