Hi, Denise:
I've attached a .zip file for the schema that is giving me the error. The feature class contains a number of fields, many of which have domains (but no subtypes). It doesn't seem like a lot, but then again, how many is too many? Incidentally, I
I checked the schema out to AXF format, rather than shapefiles. On the mobile device I was installing it on the main memory rather than SD card. Don't think there are any other programs running in the background, at least none that I'm starting manually. My ArcPad Today plugin only contains the default shortcut to ArcPad. The only extensions turned on are JPEG and JPEG2000.
As for the Windows Mobile OS, the Mesas are running version 6.5 and the Archer version 6.1. Suppose I could upgrade the Archer to 6.5, but that's also having trouble on the Mesas. And I have no idea where/how to check on the GPS firmware for either of these devices.
Am checking with my ESRI folks here to see if we are current in our ArcPad maintenance. If so, will submit a support request. But wanted to get you these answers and attachment without further delay.
Thanks in advance,
Doug
