ArcPad 10 How do you customize Find Features to just be the query & results tabs?
810
08-21-2012 10:55 AM
JessicaPutra
I used ArcPad Data Manager through ArcGIS to export my GDB files for disconnected editing on a laptop.
The find features button in ArcPad shows every layer in a separate tab (this makes for a lot of tabs), then at the end of the tabs is the Query-Results-Location tabs.
My field crews just need the Query & results tabs, as the quickest way to navigate around the map. Is there a way to disable/remove all of the feature layer tabs in the Find Features tool? Do I have to make a custom tool to do this?
I feel like every time I have to update all of our laptops, I spend a lot of time customizing everything to make it look right.
Help is appreciated.
Thanks!
Tags (3)
deleted-user-UTJky-a2zq3q
If you have not already found it, please refer to the link below. I was looking for the same solution today and found it here!
http://forums.arcgis.com/threads/48968-ArcPad-10-Find-Features-Has-Extra-Tabs-Appearing-(My-Editable...
