Zoom to Layer refresh not working
4718
7
11-16-2013 12:43 PM
DariusDarius
Hi, what im trying to do is to zoom 2 times, with 3 seconds pause between zooms.
public void ZoomToLayerInTOC(ESRI.ArcGIS.ArcMapUI.IMxDocument mxDocument)         {             if (mxDocument == null)             {                 return;             }             ESRI.ArcGIS.Carto.IActiveView activeView = mxDocument.ActiveView;              // Get the TOC             ESRI.ArcGIS.ArcMapUI.IContentsView IContentsView = mxDocument.CurrentContentsView;             ESRI.ArcGIS.Geometry.IEnvelope envelope = activeView.Extent;            // ESRI.ArcGIS.Geometry.IEnvelope envelope = activeView.Extent;             envelope.Expand(0.75, 0.75, true);             activeView.Extent = envelope;             activeView.Refresh();             System.Threading.Thread.Sleep(3000);             envelope.Expand(0.75, 0.75, true);             activeView.Extent = envelope;             activeView.Refresh();             System.Threading.Thread.Sleep(3000);             // Get the selected layer             System.Object selectedItem = IContentsView.SelectedItem;             if (!(selectedItem is ESRI.ArcGIS.Carto.ILayer))             {                 return;             }             ESRI.ArcGIS.Carto.ILayer layer = selectedItem as ESRI.ArcGIS.Carto.ILayer;               // Zoom to the extent of the layer and refresh the map             activeView.Extent = layer.AreaOfInterest;             activeView.Refresh();         }
And after clicking button i get zoomed in after 6 seconds. Like there's no refresh after first zoom, although map scrollbars gets smaller.
JeffMatson
Thanks for replying. Well im not really sure what am I supposed to do. I mean I don't know how. By Separate thread you mean create a function? 😞
Have you tried making a call to Application.DoEvents* in between the first Refresh and the Sleep?
*warning - many people have strong feelings about using DoEvents
AlexanderGray
Honored Contributor
I think you might only be able to do this with a timer (which runs on a seperate thread, so beware of threading.)  I tried it and looks like the view waits for the processing (sleep) to be finished on the main thread before it redraws.
DariusDarius
JeffMatson
DuncanHornby
MVP Notable Contributor
I use Application.DoEvents all the time in my VB .net applications; love it, usually resolves all those sorts of screen refresh problems and I've never observed any significant slowing down of the application. This is how I would call it in VB.
Dim App As New Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase
App.DoEvents()
deleted-user-VeC5jUIlNXtq
Sorry to jump in...but could you explain what you mean by people have strong feelings?
I just wrote myself a note to test .DoEvents in some of the applications I develop/maintain, but you got me curious.
Thanks 🙂
DariusDarius
Well i tried and to my surprise ... it worked! 🙂 Thank you very much!
JeffMatson
No problem, glad you got it working.
Duncan and Geoff, here is one thread that illustrates why I added a note of caution:
http://stackoverflow.com/questions/5181777/use-of-application-doevents
Like you, I've been using it (sparingly) for years without noticing any negative side effects - I just didn't want the original poster to be caught unaware, in case "the boss" had a vendetta against DoEvents 🙂
