Not running tool
1455
11-21-2013 12:31 AM
NestorasPapadopoulos
Hallo,
I have made an Add-In tool using Visual Studio 2010 for ArcMap 10.0
I added it with the Add-In Manager in a custom toolbar, but when I pressed
the button nothing happend. It should select and move a polygon shapefile (poly_C1toend)
according to the coordinates of a selected row of a point shapefile (trig_srtm30). Then it should
run a tool (topo_iter) mabe in model builder from a custom toolbox (Toolbox_g).
Can anyone help me with that?
Here is the code
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Geometry
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS
Public Class Tool1
    Inherits ESRI.ArcGIS.Desktop.AddIns.Tool
#Region "Select Map Features by Attribute Query"
    '''<summary>Select features in the IActiveView by an attribute query using a SQL syntax in a where clause.</summary>
    '''<param name="activeView">An IActiveView interface</param>
    '''<param name="featureLayer">An IFeatureLayer interface to select upon</param>
    '''<param name="whereClause">A System.String that is the SQL where clause syntax to select features. Example: "CityName = 'Redlands'"</param>
    '''<remarks>Providing and empty string "" will return all records.</remarks>
    Public Sub SelectMapFeaturesByAttributeQuery(ByVal activeView As IActiveView, ByVal featureLayer As IFeatureLayer, ByVal whereClause As System.String)
        If activeView Is Nothing OrElse featureLayer Is Nothing OrElse whereClause Is Nothing Then
            Return
        End If
        Dim featureSelection As IFeatureSelection = TryCast(featureLayer, IFeatureSelection) ' Dynamic Cast
        ' Set up the query
        Dim queryFilter As IQueryFilter = New QueryFilterClass
        queryFilter.WhereClause = whereClause
        ' Invalidate only the selection cache. Flag the original selection
        activeView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
        ' Perform the selection
        featureSelection.SelectFeatures(queryFilter, esriSelectionResultEnum.esriSelectionResultNew, False)
        ' Flag the new selection
    End Sub
#End Region
#Region "Clear Selected Map Features"
    '''<summary>Clear the selected features in the IActiveView for a specified IFeatureLayer.</summary>
    '''<param name="featureLayer">An IFeatureLayer</param>
    '''<remarks></remarks>
    Public Sub ClearSelectedMapFeatures(ByVal activeView As IActiveView, ByVal featureLayer As IFeatureLayer)
        If activeView Is Nothing OrElse featureLayer Is Nothing Then
            Return
        End If
        ' Clear the selection
        featureSelection.Clear()
    End Sub
#End Region
#Region "MoveFeatures"
    Public Sub MoveFeatures()
        Dim pEditor As IEditor
        Dim pEndPoint As IPoint
        Dim pEnumFeature As IEnumFeature
        Dim pFeature As IFeature
        Dim pFeatureEdit As IFeatureEdit
        Dim pID As New UID
        Dim pInvalidArea As IInvalidArea
        Dim pLine As ILine
        Dim pMoveSet As ISet
        Dim pSpatialReference As ISpatialReference
        Dim pStartPoint As IPoint
        Dim myApplication As IApplication
        Dim origX As Double
        Dim origY As Double
        Dim bInOperation As Boolean
        Dim pX As Double
        Dim pY As Double
        On Error GoTo ErrorHandler
        'Get a reference to the editor extension
        pID = "esriEditor.Editor"
        pEditor = myApplication.FindExtensionByCLSID(pID)
        'Create an edit operation enabling undo for the operation
        pEditor.StartOperation()
        bInOperation = True
        'Make sure something has been selected
        If pEditor.SelectionCount = 0 Then Exit Sub
        'Add all the editor's selected features to a new set
        pEnumFeature = pEditor.EditSelection
        'Flag those areas of the display that need refreshing
        pInvalidArea = New InvalidArea
        pInvalidArea.Display = pEditor.Display
        pInvalidArea.Add(pEnumFeature)
        pMoveSet = New esriSystem.Set
        pEnumFeature.Reset()
        pFeature = pEnumFeature.Next
        Do While Not pFeature Is Nothing
            pMoveSet.Add(pFeature)
        Loop
        'Reset the Set
        pMoveSet.Reset()
        'MoveSet requires a line to specify the new location'Use the selection anchor as a starting point for the line
        pStartPoint = pEditor.SelectionAnchor.Point
        pLine = New Line
        pStartPoint.QueryCoords(origX, origY)
        pEndPoint = New Point
        'offset the selection by pX units in the x direction, pY units in y direction
        pEndPoint.PutCoords((origX + pX), (origY + pY))
        pLine.PutCoords(pStartPoint, pEndPoint)
        'Get the spatial reference from the map and assign it to the new line
        pSpatialReference = pEditor.Map.SpatialReference
        pLine.SpatialReference = pSpatialReference 'Set the spatial reference of the new line'Do the move while looping through the set
        pFeatureEdit = pMoveSet.Next
        Do While Not pFeatureEdit Is Nothing
            pFeatureEdit.MoveSet(pMoveSet, pLine) 'Move all the selected features 50 units to the right
        Loop
        'Stop the Edit Operation
        pEditor.StopOperation("Move Selection")
        bInOperation = False
        pInvalidArea.Invalidate(esriAllScreenCaches)
        'Additionally move the selection anchor
        pEditor.SelectionAnchor.MoveTo(pEndPoint, pEditor.Display)
        Exit Sub
ErrorHandler:
        If bInOperation Then
            pEditor.AbortOperation()
            MsgBox("Error moving features.  Check selected features for topological associations.")
        End If
    End Sub
#End Region
    Public Sub New()
        ' select coords and assign to variables by select Map Features by Atribute Query
        Dim row As Integer
        Dim pX As Double
        Dim pY As Double
        row = 0
        SelectMapFeaturesByAttributeQuery(activeView, trig_srtm30, "FID=row")
        pX = trig_srtm30.X.Value
        pY = trig_srtm30.Y.Value
        ' Clear selection
        ClearSelectedMapFeatures(activeView, trig_srtm30)
        ' select polygon shapefile which will be moved by select Map Features by Atribute Query
        SelectMapFeaturesByAttributeQuery(activeView, poly_C1toend, "")
        ' move shapefile according to new coords
        MoveFeatures()
        ' make calculations by the tool made by modelbuilder
        ' Create workspacefactory
        Dim pToolboxWorkspaceFactory As IWorkspaceFactory
        pToolboxWorkspaceFactory = New esriGeoprocessing.ToolboxWorkspaceFactory
        'Open a toolbox workspace - you need to change the path
        Dim pToolboxWorkspace As IToolboxWorkspace
        pToolboxWorkspace = pToolboxWorkspaceFactory.OpenFromFile("C:\akis\my data\documents\proffesional\geoid_works\rasters", 0)
        ' Connect to tool - you need to change the toolbox name and model name
        Dim pGPToolBox As IGPToolbox
        pGPToolBox = pToolboxWorkspace.OpenToolbox("Toolbox_g.tbx")
        Dim pGPTool As IGPTool
        pGPTool = pGPToolBox.OpenTool("topo_iter")
        ' Run tool
        Dim pGPToolCommandHelper As IGPToolCommandHelper
        pGPToolCommandHelper = New GPToolCommandHelper
        pGPToolCommandHelper.SetTool(pGPTool)
        pGPToolCommandHelper.Invoke(Nothing)
        ' Destroy objects
        pToolboxWorkspaceFactory = Nothing
        pToolboxWorkspace = Nothing
        pGPToolBox = Nothing
        pGPTool = Nothing
        pGPToolCommandHelper = Nothing
    End Sub
    Protected Overrides Sub OnUpdate()
        Enabled = My.ArcMap.Application IsNot Nothing
    End Sub
    Private Function activeView() As IActiveView
        Throw New NotImplementedException
    End Function
    Private Function trig_srtm30() As IFeatureLayer
    End Function
    Private Function poly_C1toend() As IFeatureLayer
    End Function
    Private Function esriAllScreenCaches() As Short
    End Function
End Class
DuncanHornby
MVP Notable Contributor
A Tool requires you to interact with the map display, was this your intention? A button is a control you click on and something happens (e.g. zoom to full extent).
Your code does not seem to have the Sub that handles the event. So for a Tool you would expect to see an OnMouseDown event if your button was a Tool button or an OnClick Sub if it is a standard button.
Thanks for replying me! Excuse me if I seem boring but I am new to Arcobjects and I need to get used to it.
I n my code I replaced
Public Sub New()
with
Public Sub OnMouseDown()
but still nothing happens. I was wondering if it is just the correct place
of OnMouseDown or is there any other mistake in the whole code??
DuncanHornby
You still need a NEW sub, that's required to instantiate the object, in your case a Tool. I would look at this page to help you understand how to build an addin.
