Wix and Esri
1236
01-11-2013 07:19 AM
KumaravelUmapathy
How do we install esri custom toolbar and extension using wix. I searched online with no use.
(If you could help me with sample code that would be great.)
RichardWatson
There are 2 parts to the question.  The first is how to install "custom toolbar and extension" and the second is how to use Wix.
I suspect that you want is for someone to post a sample which does this so that you can edit it.  As of this writing, I don't think that you are going to find this.
Searching the forums for Wix, this is the closest match I found:
http://forums.arcgis.com/threads/5678-wix-and-esri-component-registration-gt-best-practice-lt
artifact
I went ahead and added a sample wix script to the thread linked above.
