Windows Services with ArcObjects?
952
04-24-2012 04:24 PM
shay-geo
I saw following ESRI Technical guide on Windows service and use of ArcObjects.
http://support.esri.com/en/knowledgebase/techarticles/detail/29473
We are using MapObjects in windows service and it seems to be working flawless in terms of data updates to SDE. We wanted to migrate it to ArcObjects. What will be the best option to use ArcObjects in our Windows Service?
Any input will be appreciated.
Thanks and Regards,
Shay ....
RichardWatson
Technically speaking, I think that Engine would be the way to go.  The problem with this approach is that I believe that it may well violate contractual terms and conditions.
I belive, and your link confirms, that ESRI wants you to use ArcGIS Server.
shay-geo
Thank you Richard.
We will use ArcGIS Server for it then.
