Windows forms does not work in ArcGIS Add-ins
2999
04-02-2011 12:37 PM
AnwarAhmad
I am trying to use load forms in Add-ins, but it doesnt work. If anyone have any idea please help.
Ahmad
MicheleVittorio
you can create forms writing some code. Using VB you can start with something like this:
Dim myForm As New Windows.Forms.Form
Dim myCombo As New Windows.Forms.ComboBox
Dim myCreate As New Windows.Forms.Button
myForm.StartPosition = FormStartPosition.CenterScreen
myForm.Height = 110
myForm.Width = 150
TimTeaford
Hi Ahmad,
To open or load a windows form in ArcGIS 10 add-ins, you need to make the following changes to the class module that is created with the add-in.  This example shows how to open a windows form from a button add-in.
In the class module, create a class-level variable:
>> Private myForm As New frmMain
In the OnClick event, add the following code:
>> myForm = New frmMain
>> myForm.Show()           ' to open the form as modeless window
>> 'myForm.ShowDialog()  ' to open the form as modal window
In my code below, I first check to see if the window is already open before I call the code to open the form.
>> If myForm IsNot Nothing AndAlso myForm.Visible = False Then
Public Class Test_Button
  Inherits ESRI.ArcGIS.Desktop.AddIns.Button
    Public Sub New()
    End Sub
    Protected Overrides Sub OnClick()
        End If
    End Sub
  Protected Overrides Sub OnUpdate()
    Enabled = My.ArcMap.Application IsNot Nothing
  End Sub
End Class
Ahmad
