9.3 to 10 VB6 tool help
1416
04-06-2011 11:41 AM
TonyAlmeida
MVP Regular Contributor
I had this tool in 9.3 vb6 that work great. Now that i have update to 10 my tool is broken. I've tried figuring it out but i have not had any luck. Can some one please take a look? it errors at " If tmpPoint1 Is Nothing Then". Thanks.
Private Sub UIToolControl1_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
'Adds a point to a shapefile
    Dim pMap As IMap
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Set pMap = pMxDoc.FocusMap
    Dim pDataset As IDataset
    Dim pFeature1 As IFeature
    'Dim tmpPoint1 As IPoint
    'Get the first layer in the map
    Dim pFeatLyr As IGeoFeatureLayer
    Set pFeatLyr = pMap.Layer(0)
     'Create a point from the mouse down click
    Dim tmpPoint As IPoint
    Set tmpPoint = New Point
    Set tmpPoint = pMxDoc.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y)
    'Get the feature class
    Dim pFClass As IFeatureClass
    Set pFClass = pFeatLyr.FeatureClass
'QI from IFeatureclass to IDataset
'Dim pDataset As IDataset
Set pDataset = pFClass
'Get the Workspace from the IDataset
Dim pWorkspace As IWorkspace
Set pWorkspace = pDataset.Workspace
'QI from IWorkspace to IWorkspaceEdit
Dim pWorkspaceEdit As IWorkspaceEdit
Set pWorkspaceEdit = pWorkspace
'Start editing if needed
If Not pWorkspaceEdit.IsBeingEdited Then
pWorkspaceEdit.StartEditing (True)
End If
'Start an edit operation
pWorkspaceEdit.StartEditOperation
    'Create the new point feature
    Dim pFeature As IFeature
    Dim dblDist As Double
    If button = 2 Then
        Set pFeature1 = Nothing
        Set tmpPoint1 = Nothing
        Exit Sub
    End If
    If pFeature1 Is Nothing Then
            Set tmpPoint1 = tmpPoint
        Else
            Set pFeature = pFClass.CreateFeature
            Set pFeature.Shape = tmpPoint
            If Not tmpPoint1 Is Nothing Then
                dblDist = 0
                dblDist = GetDistance1(pFeature)
                pFeature.Value(pFeature.Class.Fields.FindField("Distance_")) = dblDist
                pFeature.Value(pFeature.Class.Fields.FindField("SiteNum")) = (dblDist / 5.28) + InputBox("Enter Address Range") & ""
                pFeature.Store
            End If
            Set pFeature1 = pFeature
        End If
    Else
        If Not pFeature1 Is Nothing Then
            dblDist = 0
            dblDist = GetDistance(pFeature1, pFeature)
            pFeature.Store
        End If
    End If
'Complete the edit operation
    'pWorkspaceEdit.StopEditOperation
    pMxDoc.ActiveView.Refresh
    pMxDoc.UpdateContents
End Sub
Function GetDistance1(pFeature1 As IFeature) As Double
    Dim pGeom1 As IGeometry
    Dim pGeom2 As IGeometry
    Dim pProx As IProximityOperator
    Set pGeom1 = tmpPoint1
    Set pGeom2 = pFeature1.Shape
    Set pProx = pGeom2
    dblDist = pProx.ReturnDistance(pGeom1)
    'MsgBox dblDist
    GetDistance1 = dblDist
End Function
Function GetDistance(pFeature1 As IFeature, pFeature2 As IFeature) As Double
    Set pGeom1 = pFeature1.Shape
    Set pGeom2 = pFeature2.Shape
    Set pProx = pGeom2
    'MsgBox dblDist
    GetDistance = dblDist
End Function
TonyAlmeida
It seems to not recognize the first click temp.
Anyone have any suggestions, ideas or thoughts?
