Why esriSpatialRelTouches relation does not work?
2524
01-29-2012 10:14 PM
DemetrisDemetriou
I have two feature layers. The first one is just a polygon and the other one consists of a series of polygons which are enclosed by the first one. Thus, some polygons of the second feature layer touch on the boundaries of the first feauture layer. I wrotre a code (the basic part shown below to identify which polygons of the second layer touches the boundary of the polygon in the first layer but while the code runs without a problem it does not identify (e.g. by giving FID with Msgbox) any such polygon whilsty it should.
Any help please?
    Dim pBlockBoundaryFC  As IFeatureClass
    Set pBlockBoundaryFC = pBlockBoundary.FeatureClass
    Dim pBlockBoundaryFields  As IFields
    Set pBlockBoundaryFields = pBlockBoundaryFC.Fields
    Dim pGeom As IGeometry
    Dim pSpatialFilter As ISpatialFilter
    Set pSpatialFilter = New SpatialFilter
    Dim pBlockBoundaryCursor As IFeatureCursor
    Set pBlockBoundaryCursor = pBlockBoundaryFC.Search(pSpatialFilter, False)
    Set pBlockBoundaryFeature = pBlockBoundaryCursor.NextFeature
    Do Until pBlockBoundaryFeature Is Nothing
    Set pGeom = pBlockBoundaryFeature.Shape
    With pSpatialFilter
    Set .Geometry = pGeom
        .GeometryField = "Shape"
        .SpatialRel = esriSpatialRelTouches
    End With
    Dim pRelOp As IRelationalOperator
    Set pRelOp = pGeom
      Set pNewParcelsFeature = pNewParcelsCursor.NextFeature
      Do Until pNewParcelsFeature Is Nothing
        FID = pNewParcelsFeature.Value(intposFID)
        If pRelOp.Touches(pNewParcelsFeature.Shape) Then
        ''Report the FID of each parcel that 'touches' the exetrnal boundary
        MsgBox FID
        End If
    Loop
    Loop
DuncanHornby
MVP Notable Contributor
Demetris,
I've restructured your code. Have a look. You should really get into the habit of documenting your code with comments, this is good programing as it allows others to follow the code easier.
Duncan
' Create Spatialfilter
' Create a cursor over all BlockBoundary
Set pBlockBoundaryCursor = pBlockBoundaryFC.Search(Nothing, False)
' Main BlockBoundary loop
 ' Get block boundary polygon and update spatialfilter
 With pSpatialFilter
 End With
 ' I am assuming you have a NewParcelFC layer
 set  pNewParcelsCursor = pNewParcelFC.Search(pspatialfilter,False)
  MsgBox FID
 loop
 ' Get next Block boundary
Loop
NeilClemmons
Honored Contributor
So you're saying you have features in one layer that are inside of a feature on another layer?  The definition of "touch" is that the geometries only share a boundary.  If one geometry is inside another then they cannot touch because their interiors intersect.
DemetrisDemetriou
Thank you both for the answers. Although I eventually did it with a different way you helped me very much. I eventually used one loop passing the pFeature from another procedures and using the Boundary property of  ITopologicalOperator Inteface.
Many thanks again.
I have given points to both of you.
