VBA - field names from GxFile/GxObject
2509
10-21-2010 07:16 AM
LornaMurison
Hi, I am trying to populate a combobox with the field names of a polygon feature class selected by the user from a GxDialog.
Here is the code so far, I can't figure out how to get from GxObject to the field names.
Thanks
Private Sub btnCatch_Click()
'Allow the user to select the catchments feature class
Dim pGxDialog As IGxDialog
Set pGxDialog = New GxDialog
pGxDialog.Title = "Select Catchments Feature Class"
pGxDialog.ButtonCaption = "Select"
pGxDialog.AllowMultiSelect = False
pGxDialog.StartingLocation = "Catalog"
Dim pGxFilter As IGxObjectFilter
Set pGxFilter = New GxFilterPolygonFeatureClasses
Set pGxDialog.ObjectFilter = pGxFilter
Dim pLayerFiles As IEnumGxObject
pGxDialog.DoModalOpen 0, pLayerFiles
Dim pLayerFile As IGxObject
Set pLayerFile = pLayerFiles.Next
'Display the name of the selected feature class in the text box
txtboxSelectedFC.Text = pLayerFile.Name
'Populate combobox with the field names from that feature class
Dim pGxFile As IGxFile
Set pGxFile = New GxFile
pGxFile.Path = pLayerFile.FullName
Dim pGxLayer As IGxLayer
End Sub
KenBuja
MVP Esteemed Contributor
This should work
    Dim pFLayer As IFeatureLayer
    Set pFLayer = New FeatureLayer
    Set pFLayer.FeatureClass = pLayerFile.InternalObjectName.Open
    Dim pFields As IFields
    Set pFields = pFLayer.FeatureClass.Fields
    Dim i As Integer
    For i = 0 To pFields.FieldCount - 1
        ComboBox1.AddItem pFields.Field(i).Name
KenBuja
This should work
    Dim i As Integer
DuncanHornby
MVP Notable Contributor
Here is an alternate but very similar approach to Ken's code:
Public Sub Test()
    ' Create dialog
    ' Define filter
    Dim pGxObjectFilter As IGxObjectFilter
    Set pGxObjectFilter = New GxFilterPolygonFeatureClasses
    ' Set dialog properties and open
    Dim pEnumGxObject As IEnumGxObject
    With pGxDialog
        Set .ObjectFilter = pGxObjectFilter
        .DoModalOpen 0, pEnumGxObject
    End With
    Dim pGXObject As IGxObject
    Set pGXObject = pEnumGxObject.Next
    Dim pGXdataset As IGxDataset
    Set pGXdataset = pGXObject
    Dim pDataset As IDataset
    Set pDataset = pGXdataset.Dataset
    Dim pFeatureClass As IFeatureClass
    Set pFeatureClass = pDataset
    ' Get fields a cycle through them
    Set pFields = pFeatureClass.Fields
    Dim i As Byte
    Dim pField As IField
        Set pField = pFields.Field(i)
        MsgBox pField.Name
    Next i
End Sub
Duncan
LornaMurison
Thank-you both very much,
I used your code, Ken and it worked perfectly.  I'd mark the question as answered if I was able to 🙂
Duncan,
I thought I had tried to go through the dataset interface with the lines below, but I had problems with it.
