Using Sqlite/Spatialite with ArcObjects and C#
4775
06-27-2015 11:43 PM
StevenPaplanus
I was wondering if there are any samples for interacting with SQLite/spatialite with c#.   I understand how to use the filegdbworkspacefactory that allows me to specify a file to create a workspace, and then from there I can get to the feature classes.  I do not see any workspace factories that seem to support SQLite and Spatialite.  In this case, I need to manipulate several feature classes and geoprocessing functions.  I know how to create the database both in c# ado.net code and arcpy createsqlitedatabase.  But no such luck on accessing the feature classes. In the past, it was simple with the workspace factories, but I need to know how to do it with the SQLite database engine.   Any help or suggestions or links to a code snippet would be appreciated.
Steve Paplanus
MitchWolberg1
Hi Steven,
here's some code that I use in Delphi which might help. There are limitations with using SQLITE in ArcMap.
SqliteSource is the full file path.
var
  pWrkspcFact   : IWorkspaceFactory ;
  pFtrWrkspc     : IFeatureWorkspace ;
  pDataset   : IDataset ;
begin
      pWrkspcFact := CoSqlWorkspaceFactory.Create as IWorkspacefactory ;
      pFtrWrkspc  := pWrkspcFact.OpenFromFile ( SqliteSource , 0 ) as IFeatureWorkspace ;
      pDataset := pFtrWrkspc.OpenTable ( 'Location' ) as IDataset ;
Mitch Wolberg,
Rockware, Inc.
