Unlocking a FeatureClass after edits
3406
06-12-2012 06:32 AM
SachaTousignant
Hello everyone,
I'm trying to see if it's possible to unlock my FeatureClass after I added some features or modified some.
Here's some of the main lines :
IFeatureBuffer featureBuffer = infosXML.FeatureclassSitesReference.CreateFeatureBuffer(); IFeatureCursor cursorReferenceInsert = infosXML.FeatureclassSitesReference.Insert(true); featureBuffer.Shape = siteCourant.ShapeCopy; cursorReferenceInsert.InsertFeature(featureBuffer); cursorReferenceInsert.Flush();
Right now after doing this code, it locks the table from the others users.
EDIT :: It seems to be locked only when adding new features by either the way with FeatureBuffer + FeatureCursor or with FeatureClass.createFeature()
When modifying existing features and storing the changes, it doesn't lock the table.
ThavitinaiduGulivindala
try releasing
featureBuffer and cursorReferenceInsert objects
e.g. in .Net, we can write Marshal.ReleaseComObject(
cursorReferenceInsert)
try releasing
SachaTousignant
try releasing
Tyvm, I didn't know about it, I'll def try it out.
Worked out, thx alot! +1
DuncanHornby
MVP Notable Contributor
Another way to release cursors is using the USING statement and ComReleaser. See the VB code below
' For ArcGIS 10 using VS 2010 you need to import the following
Imports ESRI.ArcGIS.ADF.Connection.Local
Dim pQueryFilter As IQueryFilter
pQueryFilter= New QueryFilterClass
pQueryFilter.WhereClause = "ID = 1"
Using releaser As New ComReleaser
    Dim pFeatureCursor As IFeatureCursor
    pFeatureCursor = pFeatureclass.Update(pQueryFilter, True)
    releaser.ManageLifetime(pFeatureCursor)
    Dim pFeature As IFeature
    pFeature = pFeatureCursor.NextFeature
    While pFeature IsNot Nothing
        ' Do something with pFeature
        pFeatureCursor.UpdateFeature(pFeature)
     End While
End Using
Duncan
