Trying to export a legend to a Bitmap
2237
02-21-2016 02:40 PM
AllanMills
I'm trying to export a legend that I have being displayed on a map as a separate bitmap file. I think I should be able to do it but all I get is a bitmap with nothing but black being displayed. Here is my code:
    Public Sub tryExportLegend()         Dim pMxDoc As IMxDocument         pMxDoc = m_app.Document          Dim PageLayout As IPageLayout = pMxDoc.PageLayout          'Locate the legend object         Dim graphicsContainer As ESRI.ArcGIS.Carto.IGraphicsContainer = TryCast(PageLayout, ESRI.ArcGIS.Carto.IGraphicsContainer)         graphicsContainer.Reset()         Dim currentElement As IElement         Dim storedGeom As IGeometry           currentElement = graphicsContainer.Next         While Not currentElement Is Nothing             If TypeOf currentElement Is ESRI.ArcGIS.Carto.IMapSurroundFrame Then                 CType(currentElement, ESRI.ArcGIS.Carto.IMapSurroundFrame).MapSurround.Refresh()                 storedGeom = CType(currentElement.Geometry, IClone).Clone                  Exit While             End If              currentElement = graphicsContainer.Next         End While          'Write the legend to a bitmap         Dim myDisplay As IDisplay = New SimpleDisplay         Dim outBitmap As Bitmap = New Bitmap(1000, 1000)         Dim outGraphics As Graphics = Graphics.FromImage(outBitmap)          myDisplay.StartDrawing(outGraphics.GetHdc, esriScreenCache.esriNoScreenCache)         currentElement.Draw(myDisplay, Nothing)         myDisplay.FinishDrawing()          If File.Exists("c:\temp\legendOut.bmp") Then             File.Delete("c:\temp\legendOut.bmp")         End If         outBitmap.Save("c:\temp\legendOut.bmp", System.Drawing.Imaging.ImageFormat.Bmp)      End Sub
