Start up question
2162
04-22-2013 03:36 AM
ManojrajTeli
I am new to ArcObjects SDKs am i am using Window 7 , 64 bit system, Visual studio 2010 and dot net platform 4.0 and when I try very simple code it gives following error.
Retrieving the COM class factory for component with CLSID {00A5CB41-52DA-11D0-A8F2-00608C85EDE5} failed due to the following error: 80040111 ClassFactory cannot supply requested class (Exception from HRESULT: 0x80040111 (CLASS_E_CLASSNOTAVAILABLE)).
Any help will be appreciated.
sameerpuppal
Can you paste the code which you are using as sample. also try the same code after setting framework as 3.5
