Select features
1258
05-16-2012 03:52 AM
YimanSong
I have select tool that goes through each TOC layer to find features matching the search criteria. It's very slow when there are a lot of layers in the TOC. Can anyone suggest a way to optimize the speed?
        private void cmdSelect_Click(object sender, EventArgs e)
            IMxDocument pDoc = m_application.Document as IMxDocument;
            IMap pMap = pDoc.FocusMap;
            IActiveView pActiveView = pMap as IActiveView;
            IEnumLayer pEnumLayer = pDoc.FocusMap.Layers;
            ILayer currentLayer = pEnumLayer.Next();
            IFeatureLayer pFeatureLayer = null;
            //loop through layers in TOC and select features
            //Written to accomodate grouped layers 2 levels deep
            int numLayerSelected = 0;
            while (currentLayer != null)
                if (currentLayer is IFeatureLayer)
                    pFeatureLayer = currentLayer as IFeatureLayer;
                    SelectByAtt(pFeatureLayer, pActiveView);
                    numLayerSelected = numLayerSelected + IsSelectionEmpty(pActiveView, pFeatureLayer);
                if (currentLayer is ICompositeLayer)
                    ICompositeLayer level1Layer = currentLayer as ICompositeLayer;
                    int i;
                    for (i = 0; i < level1Layer.Count; i++)
                        if (level1Layer.get_Layer(i) is IFeatureLayer)
                            pFeatureLayer = level1Layer.get_Layer(i) as IFeatureLayer;
                        if (level1Layer.get_Layer(i) is ICompositeLayer)
                            ICompositeLayer level2layers = level1Layer.get_Layer(i) as ICompositeLayer;
                            int j;
                            for (j = 0; j < level2layers.Count; j++)
                                if (level2layers.get_Layer(j) is IFeatureLayer)
                                    pFeatureLayer = level2layers.get_Layer(j) as IFeatureLayer;
            pDoc.CurrentContentsView.Refresh(0);
            //Refresh attributes dialog
            ISelectionEvents pSelEvents = pMap as ISelectionEvents;
            if (pSelEvents != null)
                pSelEvents.SelectionChanged();
                if (numLayerSelected != 0)
                    if (chkZoom.Checked)
                        ZoomToSelected(pActiveView);
                    else
                        // do nothing
                else
                    MessageBox.Show("No feature is selected");
            else
                MessageBox.Show("No features selected.");
DuncanHornby
MVP Notable Contributor
Yiman,
Next time you upload your code please place it in the code (#) tags as it makes it easier to read. You've lost all your indentation... This is particularly important if the code is Python.
DerekLoi
I ran into this problem too and the way i did it was tun off the visibility of the map control temporarily so that it doesn't have to redraw anything... which in turn makes the process go a lot faster.
i'm not sure if this is the best way of going about it but it works 🙂
