Problem creating shapefile
1014
05-21-2012 07:41 AM
MarAlcaraz1
Hello everyone!
since I installed ArcEngine, I get this error
"COM target does not implement IDispatch"
when I create a shapefile.
This code works perfectly before installing ArcEngine 😞
' Open the folder to contain the shapefile as a workspace
Dim pWorkspaceFactory As IWorkspaceFactory
pWorkspaceFactory = New ShapefileWorkspaceFactory
Dim pFWS As IFeatureWorkspace
pFWS = pWorkspaceFactory.OpenFromFile(strFolder, 0)
' Set up a simple fields collection
Dim pFields As IFields
Dim pFieldsEdit As IFieldsEdit
pFields = New Fields
pFieldsEdit = pFields
Dim pField As IField
Dim pFieldEdit As IFieldEdit
' Make the shape field
' it will need a geometry definition, with a spatial reference
pField = New Field
pFieldEdit = pField
pFieldEdit.Name2 = strShapeFieldName TargetInvocationException occurred
pFieldEdit.Typ2e = esriFieldType.esriFieldTypeGeometry
Any idea?
Thanks, Mar
MarAlcaraz1
Sorry, I have just realised that the method is name_2, not name2.
So, problem solved!!!
